Calculate Average Acceleration of Non-Uniform Cylinder Down Inclined Plane
To calculate the average acceleration of a non-uniform cylinder down an inclined plane, the equation d=vt+0.5at^2 is suggested, but its applicability is questioned due to the need for known distance and initial velocity. It is noted that the cylinder's acceleration changes based on the incline angle, with full acceleration at 90 degrees and none at 0 degrees. The discussion emphasizes the importance of understanding how incline affects acceleration compared to free fall. Clarification on the specific parameters needed for accurate calculations is sought. Overall, the conversation revolves around the complexities of applying basic kinematic equations to non-uniform motion on an incline.
Qwertyuiop123
Calculate the average acceleration of a non-uniform cylinder (large can of tomato soup) down an inclined plane.
What equation should I use?
I think the equation I should use is d=vt+0.5at^2, but I am not sure. If I use that equation, is there anything I have to assume?
I don't think you can use that equation. You'd have to know the distance and the initial velocity. Well, really, you could assume the distance to be anything and velocity to be 0 at start, but you'd have to know how long it took you to travel that distance.
So no, it won't work.
Is that honestly the entire question? If it is, then I can help a bit. What is the normal acceleration of just dropping something? Now, when you put it on an incline, it slows down, right? As in, it will still go down, but not as fast.
And if you put it on a flat surface, it won't fall at all. Okay, so at 90º it's full acceleration, and at 0º it's 0. Do you know of any function that works like that?
