What is the Average Angular Speed of the Leaning Tower of Pisa?
The average angular speed of the Leaning Tower of Pisa's top is calculated using the formula ωavg = Δθ/Δt. The tower's top moves south at an average rate of 1.4 mm/y, which converts to approximately 4.4394E-11 m/s. Dividing this value by the tower's height of 59 m results in an angular speed of 7.5244E-13 rad/s, but this answer is deemed incorrect. Possible errors include incorrect entry of powers of ten, issues with significant figures, or flaws in the grading algorithm. Clarification on these points is necessary to resolve the discrepancy in the calculation.
R.H.2010
The top of a tower much like the leaning bell tower at Pisa, Italy, moves toward the south at an average rate of 1.4 mm/y. The tower is 59 m tall. In radians per second, what is the average angular speed of the tower's top about its base?
ωavg=Δθ/Δt
I first converted 1.4 mm/y :
1.4mm/y = (1m/1000mm) × (1y/365days) × (1day/24hr) × (1hr/60min) × (1min/60sec) = 4.4394E-11
Then, I divided the above answer by 59 m : (4.4394E-11)/59m = 7.5244E-13 rad/s but this wasn't correct. Where am I making my mistake? Thank you.
Looks OK to me. I assume this is a computer-graded question. I see three possibilities (a) the formula that allows the machine to calculate the correct answer is incorrect, (b) you incorrectly entered the powers of 10 or (c) there is a problem with sig figs.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
