AvLaw - Which is the correct method of finding moles of gases?
  • Context: Chemistry
  • Thread starter Thread starter axer
    Gases Method Moles
axer
Based on your understanding of Avogadro's law.
1000 L steel storage tank contains 88.5 kg of methane gas, CH4.
Calculate no. of moles.
one method= no. of moles=mass/molar mass.
no. of moles= 88500/16.04= 5517.4 moles.other method= 1 mol= 22.4 liter.
no of moles= 1000 L/22.4L= 44.6 moles.
Please inform me of the correct method, thanks!
on Phys.org
The 22.4 L for one mole is only at S.T.P.=Standard temperature and pressure. They did not specify the temperature, but the much bigger factor here is the gas in the container is undoubtedly pressured. Assuming it is at standard temperature (zero degrees Centigrade), you could compute the pressure in atmospheres by taking the ratio of your first answer divided by your second (incorrect answer).
So 5517.4 moles is the correct number of moles? since they didn't specify the temp.
Yes, it is correct, regardless of the temperature. Upon being given the temperature, it would also be possible to compute the pressure. You would find that the gas is highly pressurized, unless it is being kept at very low temperature.
Oh by using the ideal gas law, ok thanks!
Your first answer was correct. How could you doubt it?
In this and other questions you have shown yourself to have some grasp but were easily distracted and confused by irrelevancies. Things that were related to a question but made you miss a point.
So having been partially successful and activated it is a good time, I recommend, to go back and do some revision in order to get the concepts fixed securely in your mind. :smile:
9K
11K
32K
