What is the sweet spot on a cricket bat for reducing shock to the hands?
  • Thread starter Thread starter mrajkumar
    Axial Force
The discussion focuses on calculating the axial force on a cricket bat when a ball strikes it at an angle, emphasizing the need to understand both normal and axial forces transferred to the hands. Participants suggest drawing a free body diagram and applying equations of motion to analyze the forces involved. The concept of a "sweet spot," located approximately 17 cm from the end of the bat, is highlighted as the point where shock is minimized, allowing for a more comfortable impact. Additionally, the impact's physiological effects, such as vibrations and potential injuries, are mentioned as important considerations. Understanding these dynamics can aid in designing better batting gloves and improving player performance.
mrajkumar
hi, could you tell me how to calculate the axial force (along the axis of the bat) on the bat, when the ball hits with some angle with respect to the bat longitudinal axis. The normal force on the bat I've calculated based on the impulse momentum equation.
I'm interested i calculating approximate force transferred to the hand. Normal as well as axial forces.
I've bat swing velocity, ball velocity.
Thank you
Draw an FBD of the bat, and write the equations of motion.
If you're looking at this from a physiological standpoint, such as to design a batting glove or determine the cause of a fracture, vibrations will also factor in. I don't know if that matters to you or not, and I don't know what to do about it even if so.
mrajkumar said:
... I'm interested i calculating approximate force transferred to the hand.
Try the search term "sweet spot" ... https://www.google.com/search?q=cricket bat sweet spot physics
Also applies to other bats ...
physics.usyd.edu.au said:
Batters know from experience that there is a sweet spot on the bat, about 17 cm from the end of the barrel, where the shock of the impact, felt by the hands, is reduced to such an extent that the batter is almost unaware of the collision. At other impact points, the impact is usually felt as a sting or jarring of the hands and forearm, particularly if the impact occurs at a point well removed from the sweet spot.
http://www.physics.usyd.edu.au/~cross/baseball.html
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
