Back EMF and Current Variability: A Puzzling Question
The discussion centers on the relationship between back EMF and current variability in motors. It questions the assumption that back EMF can be treated as a constant when current is not constant. The argument is made that if the magnetic field is constant, the back EMF should also vary due to changes in the area through which the magnetic field lines pass as the loop rotates. The equation E=Ir+E' is scrutinized, with E' and resistance r considered constants. Overall, the conversation highlights the complexities of back EMF in relation to changing current and magnetic field interactions.
brainyman89
while solving an exercise, i have found that they are considering the back emf of a motor constant although the current is not constant? how comes that? shouldn't it be variable as current varies?
they are considering that as E=Ir+E' where E' and r are constants?
If the magnetic field is constant then I don't see how the back emf could be constant. It will be determined by the size of the area which the magnetic field lines 'cut', and this will obviously be changing as the loop rotates.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'A scenario of non-uniform circular motion'
(All the needed diagrams are posted below) My friend came up with the following scenario. Imagine a fixed point and a perfectly rigid rod of a certain length extending radially outwards from this fixed point(it is attached to the fixed point). To the free end of the fixed rod, an object is present and it is capable of changing it's speed(by thruster say or any convenient method. And ignore any resistance). It starts with a certain speed but say it's speed continuously increases as it goes...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
