Back up battery for solar power
To power a DC motor with a solar panel and battery backup, a voltage regulator is essential to prevent overcharging the battery. The circuit design must consider the solar panel's short circuit current and open circuit voltage alongside the motor's power requirements. While a simple circuit may suffice, investing in an intelligent charger can optimize costs by potentially allowing for a smaller solar panel or battery. Off-the-shelf solutions are available, making it easier to implement effective designs without extensive custom work. Ultimately, the choice between simplicity and efficiency should be guided by economic considerations.
guitmusic11
Say you have to power a simple motor with a solar panel, but that panel does not always supply the necessary power. What is the simplest circuit that could combine a DC motor, Solar panel and battery backup to ensure that the motor will continue running even when the solar panel cannot supply power?
Assume that the PV array converts more total energy than the motor requires over the year. The battery will need sufficient capacity to supply the motor overnight in mid-winter and cloud. The motor and controls will need to operate efficiently at the battery voltage available, or a converter will be required.
A battery of chemical cells operates at a chemically determined voltage. The battery will therefore need a voltage regulator to prevent the PV array from overcharging the battery.
The minimum circuit is therefore a voltage regulator. There are many minimum solutions determined by the “short circuit current” and “open circuit voltage” of the PV panel and the power requirements of the motor.
I would make the point that, as you are spending money on a solar array and battery, why would you want to use the simplest circuit? In many circumstances, you could actually save money (smaller panel or smaller battery) by using an intelligent charger. You wouldn't need to design it yourself; there are many designs (and off the shelf units) which will do it for you.
Of course, there is nothing essentially wrong with the brute force and ignorance approach - unless the economics make it too costly.
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
Hello dear reader, a brief introduction: Some 4 years ago someone started developing health related issues, apparently due to exposure to RF & ELF related frequencies and/or fields (Magnetic). This is currently becoming known as EHS. (Electromagnetic hypersensitivity is a claimed sensitivity to electromagnetic fields, to which adverse symptoms are attributed.) She experiences a deep burning sensation throughout her entire body, leaving her in pain and exhausted after a pulse has occurred...
