- #141
- 67,034
- 19,859
ranger said:Hey berkeman, no comments on the previous circuits you posted (post #134 and #135)?
Sorry, I got buried at work for a bit. Yes, you have identified most of the bad things with [F] and [G] in my post #117.
[F] There needs to be hysteresis in the comparator part of the circuit (the LM741 opamp), and the output voltage levels need to be fixed to be TTL compatible. You make a good point that some signal conditioning of the input signal and clamping of the signal before the opamp would be a good idea, depending on the characteristics of the signal source. There are several ways to fix the output drive -- I'd probably go through an output PNP pullup stage to adjust the bipolar comparator output to TTL/CMOS levels. The other issue that I was looking for with the digital counter stages is that they are ripple counters (and worse yet, two in series), so the "output" number is not going to be valid after an input clock until all of the stages settle out. The "output" will be garbage during the rippling transitions, so whatever circuit this was being fed to would have to be carefully designed to accommodate this. A more real-world design would synchronize the output of the zero-crossing detector, and then use that synchronous signal to clock counters. The counters could be ripple counters, as long as they settle out in less than the internal clock period.
[G] Yeah, this is a dorked up version of the usual RS latch. The floating inputs are a mistake, and having two switches is a mistake, because what do the gates do if both buttons are pushed at the same time? The more traditional way to make a NOR latch is to pull both inputs to ground, and have a single-pole, multiple throw switch that can either pull up one input or the other. The switch needs to be a break-before-make type.
I have some pesky work stuff to take care of today, but I'll try to find something good to post tomorrow, maybe on synchronizing signals. In the mean time, it would be good to finish off the 555 circuit, if you folks have the time.
