How Long Does It Take for a Ball Launched Off a Cliff to Hit the Ground?
  • Thread starter Thread starter TheDoorsOfMe
    Ball
To determine how long it takes for a ball launched off a cliff to hit the ground, the initial vertical velocity can be calculated using the equation V_y = V sin(θ). The time to reach the peak can be found by setting the final vertical velocity to zero and using the equation V_f = V_y + at, then doubling this time to find when the ball returns to the cliff level. For the descent to the ground, the final velocity can be calculated with V_f = √(V_i² + 2gh) and plugged into the appropriate kinematic equation. The complexity of the final result raised concerns about the correctness of the approach. Overall, the method used appears valid, but simplification may be necessary for clarity.
TheDoorsOfMe
Ok, you have a cliff with height h and you launch a ball off of it at speed v and angle \theta. How long till it hit the ground?
(1) Vsin(\theta) = V_{y}
(2) V_{f} = V_{y} + at
(3) d = ((V_{i} + V_{f})/2)*t
Ok, so what I did was take equation (2) and set V_{f}= 0. This alllows me to solve for the time that it takes to reach peak. Multiply this result by 2 to get the time when the ball is back to the plane of the cliff. Then for the time down to the ground I used equation (3) and plugged in V_{f}= \sqrt{V^{2}_{i}+2gh} for V_{f}. Then I solved for t.
This lead to a result I feel looked to complicated for the question. Did I do this right?
Ok, I don't know why all my subscripts look like superscripts in this but they do. All those i's and f's are for intial and final velocity.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
