Ball launched off a cliff at negative angle
The problem involves a ball launched off a 60-meter high cliff at a negative angle of -15 degrees, landing 120 meters away. Participants are tasked with finding the initial and final velocities, time in the air, and the angle at which the ball hits the ground.
  • The original poster expresses confusion about the problem and attempts to switch the angle to a positive value for simplification. Other participants question this approach and suggest using equations for range and height to solve for variables.
Participants are exploring different interpretations of the problem, with some providing equations and others questioning the implications of switching angles. There is no explicit consensus on the best approach, but several lines of reasoning are being discussed.
There is mention of a policy requiring initial attempts before seeking help, and some participants are reflecting on the implications of changing the direction of motion to positive. Additionally, one participant notes challenges with angles below the horizon leading to complex numbers.
picklepie159
Ball launched off a cliff at negative angle...
So a ball is launched off a cliff 60 meters high
It is thrown at -15 degrees horizontal, and lands 120 meters away.
Find the V-initial, V-final, Time in air, and Angle at which it hits the ground
inverse tan(75)= Vx/Vy
D= VT
h=1/2g t^2
Vx= cosin(75) x V-initial
Vy=sin(75) x V-initial
I know that there's a policy that I have to try to work on the problem first before i get help, but man, I am lost. This is what I can make out.
I switched everything to positive so now its falling off the cliff at 75 degrees.
120 meters = Vx T
That's all. A little ray of guidance would be a Godsend.
PS
Would the Velocity-y be V-initial +34.6 m/s?
Because when something falls 60 meters from rest, the final velocity is 34.6 meters.
What do you mean you switched everything to positive?
switching everything positive is something i don't understand in your solution...
so my approach would be ...
Range = v*cos(-15) * t
Height = v*sin(-15)t + 1/2*g*t^2
now ... you get 2 equations in v and t and there are 2 variables... so you can solve for both...do you get it?
By switching to positive, I ust meant I flipped it upside down- the movement towards the ground is now the positive direction. Then, the angle it was thrown at is 75 degrees instead of -15. (Does that work out?)
It just makes stuff easier- no fiddly negative directions to deal with.
then don't you think the time of flight changes in both cases?
Really sorry for digging up a super old thread but I'm trying to solve a similar problem right now.
As The Legend suggested, I've solved for v and t using those equations. First, I define v in terms of R and t using the R = v * cosθ * t
v = R/(cos(θ) * t)
Then, I substitute that into the height equation...
H = (R/(cos(θ) * t)) * sin(θ) * t + 1/2 * g * t^2
and solve for t...
t = √((R * tan(θ) + H)/(g * 1/2))
Solve it using my values, then substitute that back into the velocity derivation above...
This works for angles [0..90] but anything below the horizon just craps out due to a -ve √
Where am I going wrong? This is driving me insane!
Just wanted to clarify something, the reason I add H is because I actually got
--H in my particular case..
Actually... I'm wrong.. it works for the inputs given at the top of this thread :S
I think what might actually be happening in my case is my launch angle is too much!
That is to say... the angle that is a direct line to the target location is more than the angle I'm trying to launch it at (e.g.)
Angle from Launch to Target: -10
Launch Angle: -20
That would mean its impossible, right? And why I'm getting these imaginary numbers :)
