Bar holding a weight (conceptual)
  • Thread starter Thread starter usamo42j
    Conceptual Weight
In the scenario of a rotating bar with a weight at its end, gravity acts downward on the weight, creating a potential for the bar to turn. However, the bar remains stable and does not rotate, indicating that a counteracting force is present. This force is centripetal force, which keeps the weight from moving closer to the axis of rotation. The discussion highlights the balance of forces required to maintain the system's equilibrium. Understanding these forces is crucial for analyzing rotational dynamics.
usamo42j
A long, thin metal (massless) bar is rotating in a circle at constant velocity, perpendicular to the axis of rotation. A weight is placed on the end of the bar such that there is no vertical movement of the weight or bar. What force counteracts the force of gravity on the weight?.
SkittleJuice said:
Are you sure http://en.wikipedia.org/wiki/Centripetal_force" is the right force?
Gravity is attempting to pull the weight down, which would turn the bar.
If the bar turned, the weight would get closer to the axis of rotation.
Is there a force that might be against the weight getting any closer to the axis of rotation?
(My post in your homework problem question thread. It really was just me posting both places because this question is about the same problem that you were having trouble with that you posted about in the homework forum.)
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
