Basic DC Circuit/Kirchoff problem with 2 power supplies
  • Thread starter Thread starter wellcoughed
    Dc Power
The discussion revolves around applying Kirchhoff's Voltage Law (KVL) to a circuit with two voltage supplies and multiple resistors. The user seeks clarification on calculating voltage drops, currents, and power dissipation across resistors, expressing confusion about when to add or subtract EMFs. An analogy is provided to explain KVL, emphasizing that the sum of potential changes in a closed loop must equal zero. The user successfully derives equations for two loops, calculates currents, and determines power dissipation across a resistor, but questions whether the connection to the battery affects their calculations. Overall, the method used for solving the circuit appears correct, and the calculations are validated by another participant.
wellcoughed
http://img823.imageshack.us/img823/9775/picture2mq.jpg
Uploaded with ImageShack.us
Hi
I can't get my head round Kirchoffs law. I've been alright with series and parallel circuits with one voltage supply, but I've been given a problem with two voltage supplies.
Would anyone be able to explain how I would get volt drop, current and power dissipated across these resistors please?
I also don't understand why in some cases you add the emf's and sometimes you take them away from each other
Ive been given this as an explanation to Kirchoffs Voltage law but it's just gobbledegook to me :/
"In any closed loop in a network, the algebraic sum of the voltage drops (i.e. products of current and resistance) taken around the loop is equal to the resultant emf acting in that loop"
Many thanks if you can help :)
To explain by way of analogy, think of Kirchhoff's voltage law (KVL) like a walk on a hilly terrain that ends at the same location that it starts. Clearly the sum of all the "ups" has to to equal the sum of all the "downs" along the closed path.
The same is true of KVL: If you "walk" around a closed path in a circuit the sum of the potential changes must be zero.
What causes potential changes? A battery will cause a rise or a drop depending on which direction you "walk" through it. A resistor will cause a change in potential that is set by the direction of the current that flows through it; if you walk through the resistor against the flow of current, you see a potential rise. If you walk with the current, you see a potential drop.
So, label your circuit with currents shown for each branch. Don't worry about choosing the correct direction beforehand -- the math will sort things out; if your guess happened to be "incorrect", then the math will give you a negative value for that current, meaning it's flowing in the opposite direction to your assumption.
Next label each component with "+" and "-" at its ends to show the direction of potential changes which occur in that component. For batteries it's fixed regardless of current direction. For resistors, a drop occurs in the (assumed) direction of the current flow.
Next, identify the closed paths ("circuits") you wish to "walk" around. Usually this means recognizing the obvious loops in the circuit. You only need to find enough loops so that each component is "visited" at least once. Then, for each loop, "walk" around the loop and write down the potential changes as you pass through each component. For resistors, potential change have magnitude I*R and you get the sign from the +/- labels that you made previously. When you arrive back where you started, set the sum equal to zero. This procedure will result in an equation for each loop. Solve the set of equations to find the current values.
http://img546.imageshack.us/img546/5104/shtuff.jpg
I've been asked to find the power dissipated across R3.
I'm just wondering if I'm right in my method so far?
Loop One:
-6v + R1(I1) + R3(I1-I2) = 0
I1 = 1.0471698Amps
Loop Two:
-1.5V + R2(I2) + R3(I2-I1)= 0
I2 = 0.71698112 Amps
But here's where it gets sticky...
To find the current across I3 I've done
I1-I2 = I3
1.047Amps - 0.717 Amps = 0.33Amps
I3 = 0.33Amps
Voltage Across I3 = I3 x R3
Voltage Across I3 = 0.33 x 15ohms
Voltage = 4.95V
Power dissipated across R3 = I3 x V3
Power dissipated across R3 = 0.33amps x 4.95V
Power dissipated across R3 = 1.6335Watts
But the confusion I have is the middle resistor is physically connected (+) to (-) to the 1.5V battery on the loop two side. Would this have an effect on the R3 volt drop that I haven't calculated for?
Thanks if you can help :)
But you did allow for it when you solved the two equations in two unknowns (the two currents).
so the method I've used in finding the power dissipated across R3 is correct?
And I've solved it? :)
Your numbers look fine. So yes, solved!
By the way, we usually say that voltages are "across" components, currents flow "through" components, and power is dissipated "by" components :wink: Doesn't affect your answers though :smile:
Thanks for taking the time to help me :)
Much appreciated
