Is the First-Order Differential Equation Linear in Its Dependent Variable?
pupeye11
Determine whether the given first-order differential equation is linear in the indicated dependent variable by matching it with the first differential equations given in #7.
#7 (sin \theta)y^{'''} - (cos \theta)y^{'} = 2
#10 (u)dv + (v+uv-ue^u)du = 0; in v; in u
How can I do this problem when there is not a variable y in number 10?
Underline added below.
There does not need to be a variable y. In #10 the question is in two parts: Is the differential equation linear in the indicated dependent variable - in v, and then in u. For the first part, assume that v is the dependent variable; for the second part, assume that u is the independent variable.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
