Calculating Work done on Trunk: Incline Plane Homework
In summary: Your diagram is incorrect, and you got the perpendicular force (1.3g + 425tan28) * cos28 incorrect. You should have used the vector sum of the components of P, which is (h+tan(28-theta))*cos(theta).
zaddyzad
149
A trunk of mass m = 1.300 kg is pushed a distance d = 124 cm up an incline with an angle of inclination theta = 28.0 ° by a constant horizontal force P = 425 N (see figure).
The coefficient of kinetic friction between the trunk and the incline is 0.130.
a) Calculate the work done on the trunk by the applied force P.
b) Calculate the work done on the trunk by the frictional force.
c) Calculate the work done on the trunk by the gravitational force.
http://imgur.com/ydGgOn7 http://imgur.com/ydGgOn7
My guess: (P has a component 28degrees above its horizontal, and another one pointing down perpendicular to the plane)
A) shouldn't this be W = F*D... (425/cos28)*1.24
b) shouldn't this just be W = FF * D... ((1.3gcos28+425tan28)*.13)*1.24
c)W=Fs*D... 1.3gsin28*1.24
I got all the questions wrong... can anyone tell me where I went wrong ?
For A), you should calculate force P along the incline, which is (425*cos28) not (425/cos28).
For B), you never showed any calculation for normal force!...Calculate Normal Force again!
For C), you did almost everything right except the sign. Gravity in this case is against the direction of motion.
Work done by a force is equal to the component of the force in the direction of the motion, multiplied by the distance traveled.
Check the signs, the relations for the components of P, and the energy balance.
The energy is supplied by the work done by force P.
Some energy is lost to friction.
The rest goes into gravitational potential energy.
I'm solving for the hypotenuse, the parallel component to distance, what you just said would give me the adjacent side which is the side with the known value.
you seem to have some fundamental doubt. draw the force vector and its components, in form of a "triangle sum". you'll see what I mean.
I just got B and C, so now my focus is A.
great!
zaddyzad said:
http://imgur.com/hBSSssV, I don't see where my mistake is.
You drew the triangle wrong. Force vector is the hypotenuse of the triangle, not simply its side.
Edit: If it still doesn't ring any bells, you'll need to check out vector sum and vector resolution.
425 N is the horizontal force parallel to the base of the incline.
h is what I solved for, and it is the force parallel to the direction of motion. I don't see my mistake anywhere..
Yes, it is. If you meant about my previous post, it was regarding the orange+black vector triangle.
I don't see what you're saying.
@zaddyzad: do you know how to find the components of a vector along x and y axis?
Draw the x-axis so it points up the slope - in the direction of movement.
Draw the y-axis so it points upwards away from the slope.
Now find the components of P.
The vector P should be the hypotenuse of the triangle made by the components.
The vector components are always smaller than the vector.
Look at the figure attached. It will make things clear. Here z represents your force vector P. Ignore the equation written, I copied the image off the web.
Ok, now that I got that. This now leaves me with the some new questions.
What was wrong with my vector sum diagram, I still had a component of force parallel to the plane?
And how did I get the right answer for by when I solved for the perpendicular force on the plane to be (1.3g + 425tan28) * cos28
I'm confused if I could calculate the correct vertical force with my "incorrect" triangle, why wouldn't it allow me to compute the correct parallel force?
Whenever you resolve a vector, that vector is always assumed to a hypotenuse of vector triangle. This assumption is correct. Simple trigonometry can prove it. The vector sum of adjacent sides always gives the original vector (hypotenuse).
If you check your method, then you won't the sum of new vectors to be same as the old one.
Your can try, but it won't give you the right answer!...It also depends what do you mean by vertical, the y-axis perpendicular to the incline or the regular vertical
1. What is work and how is it calculated?
Work is the measure of energy transferred when a force is applied to an object and causes it to move. It is calculated by multiplying the force applied to the object by the distance it moves in the direction of the force.
2. How do I calculate work done on an inclined plane?
To calculate work done on an inclined plane, you need to know the force applied to the object, the distance it moves along the incline, and the angle of the incline. Use the formula W = Fcosθd, where W is work, F is force, θ is the angle of the incline, and d is the distance moved along the incline.
3. What is the difference between work done on an inclined plane and a horizontal surface?
The main difference is the direction of the force and the direction of the movement. On an inclined plane, the force is applied at an angle, which means only a component of the force is acting in the direction of movement. On a horizontal surface, the force and movement are in the same direction, resulting in a higher amount of work done.
4. How does the angle of the incline affect the work done?
The steeper the incline, the greater the angle, and the less work is done. This is because the force is applied at a smaller component in the direction of movement, resulting in less work being done. On the other hand, a smaller angle of incline means a larger component of the force is acting in the direction of movement, resulting in more work done.
5. Can the work done on an inclined plane be negative?
Yes, the work done on an inclined plane can be negative if the force applied is in the opposite direction of the movement. This means that the object is losing energy as it moves down the incline, resulting in a negative value for work done.
