- 1,575
It's a lot more defined than beta which can typically run from 50 to 200 with small signal transistors. Gain figured using R'e is more predictable. R'e is the AC impedance of the base-emitter junction. Take a handful of transistors with a well designed voltage divider biased class A setup using an emitter bypass capacitor and the AC gain will be fairly consistent from one transistor to the next to the next, etc... The beta can vary quite a lot and the AC gain will be consistent. As far as building things to see what happens, this is exactly what I did in school a long long time ago, this is how I know.
Varying beta from one transistor to the next will more likely affect the Zin of the amplifier than anything else. And if the voltage divider bias resistors are set low enough they will 'swamp' this out. If the previous stage driving it has a Zout that is a decade or so below the targeted Zin then it won't likely matter.
