Basis Transformation for Wave Function
Proofrific
It's not a homework problem. I'm reading my textbook (Sakurai's Modern QM), and I'm not sure about a step (eq 3.6.6 through 3.6.8). Here it is:
We start with a wave function that's been rotated:
\langle x' + y' \delta \phi, y' - x' \delta \phi, z' | \alpha \rangle
Now, we change the coordinate basis from Cartesian to spherical. That is,
\langle x', y', z' | \alpha \rangle \to \langle r, \theta, \phi | \alpha \rangle
I want to show that the previous wave function transforms to:
\langle r, \theta, \phi - \delta \phi | \alpha \rangle
See above.
Physically, I understand that we're rotating by angle \delta \phi about the z-axis. So, it makes sense that the bra would acquire a -\delta \phi (the ket would acquire a positive). But, I'm not sure how to mathematically show the steps (which is needed for more complicated transforms, such as Sakurai eq. 3.6.10 to 3.6.11).
You are essentially acting the rotation operator, \mathcal{D}, on the bra in the spherical wavefunction:
<br /> \langle r,\theta,\phi|\mathcal{D}|\alpha\rangle=\langle r,\theta,\phi\left|1-i\left(\frac{\delta\phi}{\hbar}\right)L_z\right|\alpha\rangle=\langle r,\theta,\phi-\delta\phi|\alpha\rangle<br />
Mathematically, you are multiplying each term in \langle r,\theta,\phi| by \mathcal{D}, but since L_zr=L_z\theta=0, you are left with
<br /> \langle r,\theta,\phi|\mathcal{D}=\langle r\mathcal{D},\theta\mathcal{D},\phi\mathcal{D}|\rightarrow\left.\langle r,\theta,\phi\left(1-i\left(\frac{\delta\phi}{\hbar}\right)L_z\right)\right|=\langle r,\theta,\phi-\delta\phi|<br />
Equations (3.6.10) and (3.6.11) use the "known result from wave mechanics" in Equation (3.6.9):
<br /> \langle\mathbf{x}&#039;|L_z|\alpha\rangle=-i\hbar\frac{\partial}{\partial\phi}\langle\mathbf{x}&#039;|\alpha\rangle<br />
and this is not the same as the second equation above because you do not have the \propto(1-\delta\phi L_z) acting on the bra, you just have L_x, L_y, or L_z. Converting L_x and L_y from Cartesian into spherical should give you Equations (3.6.10) and (3.6.11) when using the "known result" of Equation (3.6.9)
Thanks for the help!
How do you know that L_zr=L_z\theta=0? The only thing I remember about L_z is how it acts on an eigenstate: L_z|l,m\rangle = m \hbar | l,m \rangle. How do you know how it acts on r, \theta, and \phi?
Well L_z is an operator equivalent to
<br /> L_z=-i\hbar\frac{\partial}{\partial\phi}<br />
So since r and \theta have no \phi component, L_z acting on them would be zero.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
