Batteries at freezing temperatures
Developing a battery-operated invention for sub-freezing conditions presents challenges, particularly regarding battery performance at low temperatures. NiCd batteries function down to -40°C, but their legality in the EU is a concern, while NiMH and lead-acid batteries fail at -20°C. Lithium batteries are effective in cold conditions but are more expensive. A potential solution is to integrate a rechargeable battery into the product and source suitable batteries from an OEM, ensuring compatibility and brand recognition. Clear communication about battery requirements is essential for consumer understanding and safety.
alexwryt
I am trying to develop a battery operated invention that will be used primarily in sub freezing conditions. From what I can tell from my research so far, a simple 9 volt NiMH or lithium will work fine under these conditions. The only problem I foresee though is that when this was eventually a product out on the market, I doubt the general public as a whole would heed the package warning of only using NiMH or lithium batteries
As a workaround I've thought of integrating a rechargeable battery into the product itself but am unsure what type of battery would be ideal and also cheap. (Basically I'd like to be able to turn a DC motor with a small load for at least 2 hours)
NiCd work down to -40°C whereas NiMH, lead acid, LiO stop working at -20°C. NiCd can be recharged, but seems to become illegal now in the EU. Lithium stuff is expensive, but appearently can be made to work in the cold too.
You can always purchase the batteries that you feel would fit best in your device from an OEM. From there, put your companies name on it and add a little premium. Then, only support your device with those said batteries (but of course let your battery chemistry be known)...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
