Beam and Support Force Question
A 7.20m rigid beam with a mass of 105.9kg is supported at both ends, with a 64.8kg student standing 1.33m from one end. The problem requires calculating the upward force exerted by each support. Previous attempts yielded incorrect values of 826 for support 1 and 847 for support 2. The discussion suggests using the equations of static equilibrium rather than moment of inertia to find the correct reactions. Proper application of static equilibrium principles will lead to the correct solution for the support forces.
G.T
A 7.20m long rigid beam with a mass of 105.9kg is supported at each end. A 64.8kg student stands 1.33m from support 1. How much upward force does each support exert on the beam? (Enter your answer for support 1 first, followed by your answer for support 2.)
Incorrect. Tries 9/10 Previous Tries https://loncapa.physics.mcmaster.ca/enc/52/7bfddd85ead53c8f14583bfd85d890dbb8c568726a65d4d6649059f2d0ac61a9b89dce375e2817b5025710e5afbd449840c9f4eb4d76711b0370f0e564254ec091780c11a4a72cd5.png
Moment of Inertia
I keep getting 826 for t1 and 847 for t2[/B]
Moment of Inertia
"Moment of inertia", whatever that means, is not how you solve this problem.
Try writing the equations of static equilibrium for this beam, and then using them to solve for the unknown reactions.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
