Behavior of a cylindrical magnet
When a cylindrical magnet is rolled on a smooth metal surface, it exhibits resistance and 'pops' forward rather than rolling smoothly. This behavior suggests that the magnet has a preferred orientation when sticking to the surface. The non-uniform distribution of the magnetic field and the orientation of magnetic domains in the magnet contribute to this phenomenon. The interaction between the magnet and the metal surface affects its movement, leading to the observed jerky motion. Understanding these magnetic properties can explain the magnet's behavior during rolling.
overlook1977
I noticed when I stick a cylindrical magnet on a smooth metal surface (longways) and roll the magnet along the surface, it does not roll smoothly. Instead, it seems to resist movment, then 'pop' forward into another position. It is almost as if the magnet has a preference on which side sticks to the surface. Anyone have any ideas about this?
The magnetic field or (orientation/distribution of domains in the cylindrical magnet) are not uniform, and therefore there is a preferred orientation, and that would interfere with the 'smooth' motion.
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
