Maximizing Usable Air from Decompressing a Scuba Tank
  • Thread starter Thread starter qwerty1785
    Air Behavior
To determine the usable air from decompressing a standard 80 cu ft scuba tank from 3000 psi to 100 psi, Boyle's Law can be applied, considering the relationship between pressure and volume. The total volume of air at room temperature will be approximately 80 cubic feet when fully expanded. The actual volume of the tank is about 0.39 cu ft, and the remaining air volume at 100 psi can be calculated by converting the pressure to atmospheres and applying Boyle's Law. It is noted that while air behaves similarly to an ideal gas under certain conditions, real gas behavior may need to be considered due to temperature changes during decompression. Ultimately, the calculations will yield the exact amount of usable air available.
qwerty1785
I need to find the amount of usable air from decompressing a scuba tank from 3000psi to 100 psi. The tank is a standart 80cu ft scuba tank and the air is being drawn from the tank at a rate of 1.5 cubic feet per minute and 100 psi at 20 celsius.I know that air is not an ideal gas but am not sure if I can assume it will behave similar here so ideal gas law might not work. would van der waals equation be what I need? I know the air decompressing that much will get very cold and not be as much volume as ideal, but how much is it exactly?
You're going to end up with 80 cubic feet of air when it reaches room temp.
The actual volume of the tank is is .39 cu ft.
If the total volume of room air is 80cu ft, one can figure out the volume of air remaining in the tank at 100 psi. Hint: use Boyles law and the fact one atmosphere=14.7psi
Then subtract this from the entire capacity of 80.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
