Behavior of foam: floating vs. submerged
The discussion focuses on the behavior of foam, particularly soap bubbles, in a cylindrical glass. Bubbles near the top are more spherical and pliable, while those at the bottom become more asymmetric and compressed due to drainage and pressure. The surface width of bubbles increases with depth, potentially leading to more soap volume than air volume at the bottom. The system is dynamic, influenced by liquid drainage and the interactions between bubbles. Additional inquiries include the effects of sound waves on soap bubbles and the minimum viscosity required for a medium of soap bubbles.
Loren Booda
Consider a cylindrical glass containing a column of foam. How do the characteristics (e.g. size, geometry, surface width, air pressure, etc.) of the bubbles near the top differ from those near the bottom?
Andy,
Thanks for the specification. I was thinking about a foam of soap bubbles. Thus, I believe them pliable and closed cell.
The book you refer to is a bit pricey and extensive for my own needs here on PF, but I appreciate your recommendation in general.
I am under the impression that a column of soap bubbles compresses somewhat like the atmosphere does, exponential in character, but more visualizable.
The bubbles might form more complex geometry while progressing down the column -- more spherical near the top and more asymmetric near the bottom.
Also, bubble surface width on average would increase with increasing depth, to the extreme where there would be more soap volume than air volume.
Any contributions?
Inspiring images and videos%
I wonder if a soap bubble has a limit for the number of neighboring bubbles.
What would be the effect of a sound wave passing through a medium of soap bubbles?
What is the minimum viscosity for a medium of soap bubbles?
I think it's easist first to watch a short vidio clip I find these videos very relaxing to watch .. I got to thinking is this being done in the most efficient way? The sand has to be suspended in the water to move it to the outlet ... The faster the water , the more turbulance and the sand stays suspended, so it seems to me the rule of thumb is the hose be aimed towards the outlet at all times .. Many times the workers hit the sand directly which will greatly reduce the water...
