I Is Superdeterminism a Plausible Explanation for Quantum Mechanics?
facenian
Hello, I would like to hear some comments on this:
Recently a paper has been published(Sánchez-Kuntz, N. & Nahmad-Achar, E. Found Phys (2018) 48: 27. https://doi.org/10.1007/s10701-017-0126-z) claiming tha QM has a local realist interpretaion.
In this paper it is asserted that:
"The wave nature (as in the double-slit experiment) arises when one observes the statistical behaviour of a
large ensemble of particles, just as ripples in water arise from a statistical behaviour of many water particles, or electromagnetic waves, in quantum theory, are the result of a large collection of photons. We see the phenomenon of superposition in waves, but not in the individual particles which are the building blocks (physical entities) in QM".
This assetion seems to be in contradiction with the the double slit experiment that were performed with individual particles that showed explicitly wave like behavior of individual photons.
Am I correct or this kind of experiments were not actually performed and are only thought experiments?
After my usual objection that this paper does not meet PF requirements for discussion:
The paper imposes a new requirement to the Bell logic, called "factuality". This requirement is the base for the paper, as I read it. It says:
"Under the factuality condition, each of these sets of [counterfactual] outcomes must come from a different set of hidden variables."
I don't see any reason to include this. In fact, I would initially say that it makes no sense as a requirement. Counterfactual outcomes should be pulled from an overlapping set of hidden variables. Any comments?
Likes Mentz114
Single electron interference has been observed. I have references somewhere.
This paper seems to throw away most of standard QM so it is not discussing Bell etc but something else.
Mentz114 said:
Something very similar available here
https://arxiv.org/abs/1605.08493[/QUOTE
It's the same paper
would like to know why it does not meet PF requirements since it has been published in a peer reviewed journal.
If it is a known established fact then I am disappointed since, at least this statement, should not have passed the peer review process.
This experiment has passed peer review
arXiv:1210.6243v1 [quant-ph] 22 Oct 2012
facenian said:
Interesting, can you give us the precise citation data?
PACS numbers: 03.65.-w, 03.75.-b, 41.75.Fr, 41.85.-p, 42.25.Fx
I just clicked the link and copied this off the abstract page.
I see a number of obvious issues.
1. They assume deterministic time evolution of the entangled state, for example. There isn't the slightest piece of experimental evidence for that, and every indication that time is NOT a factor.
2. Their overall logic seems to be: if you assume X (in this case a thing they call Factuality), then Bell fails. So OK, I reject Factuality - something I see no reason to assume in the first place - and ergo their paper fails totally.
3. They include the detector settings as part of the hidden variables. That's essentially contradicted by experiments in which locality is strictly preserved.
4. And of course the real killer is this: failure to take the DrChinese challenge! :smile:
I really don't get it. Not just the paper, but that it was accepted for publication. I do not consider the reference suitable myself; but I realize that if your standard is simply that it is published in X publication, then it is automatically suitable. For papers such as this, I hardly consider it meaningful that it is published. The top publications don't even consider "Bell-is-wrong" papers because they are such a time waster for everyone involved.
Likes Lord Jestocost and Mentz114
I see nothing about single electron interference in that experiment (nor what a single electron having "interference" would mean)
article said:
In two separate landmark experiments, individual electron detection was used to build up interference patterns
Which seems to me to be pretty standard ensemble QM observation.
I just stop at this one:
Article Rings a Bell said:
In our view, non-local correlations emerge from the deterministic evolution of a shared hidden variable between two components of an ontological pair. Entanglement arises every time two (or more) physical entities share hidden variables
If a hidden variable is shared (and not copied/identical), it is by definition non-local. I kind of agree with that, because that's what Bell's is all about...
I really don't understand what the authors are talking about.
Bell's hidden-variable model assumed the existence of functions A(a, \lambda) and B(b, \lambda) with the interpretation that:
  • If Alice measures the spin of her particle along axis a, and the hidden variable has value \lambda, then the result will be A(a,\lambda)
  • Similarly, if Bob measures his particle along axis b, he will get B(b,\lambda)
Bell assumes that A(a,\lambda) and B(b,\lambda) are both well-defined for all possible values of a, b, \lambda.
In contrast, in this paper, they seem to be assuming that for every value of \lambda, there is only one pair of axes, (a,b) such that A(\pm a,\lambda) and B(\pm b,\lambda) are well-defined.
But what's supposed to happen if a twin pair is produced with some value \lambda, and then later Alice and Bob choose values for a, b for which A(a,\lambda) or B(b,\lambda) are not well-defined?
If they are assuming that that never happens, then they are talking about superdeterminism, which has long been acknowledged as a logically possible (though implausible) loophole to Bell's theorem.
No, it's not nonlocal if it is only shared by particles with a common past. Bell assumed local shared hidden variables, and showed that they cannot produce the correlations of the EPR experiment. He definitely didn't assume that shared hidden variables must be nonlocal. They must be nonlocal to agree with QM, but they aren't nonlocal just because they are shared hidden variables.
Then you haven't quite understood Bell's reasoning.
Indeed, but you cannot call that "local shared hidden variables", which is a contradiction. They are simply identical hidden variable.
Of course he didn't. This would be in total contradiction with classical thinking. Instead he build some kind of "reduction ad absurdum", except that the reduction is made by experiment.
I am sorry but the two parts of your sentence are unrelated. I don't know what "sharing" mean for you, but it has an unique ubiquitous sense. If we share a house, we do it from the common past were we got entangled by signing that real-estate contract. If some property of the house change, it change instantly for both of us.
Bell proved nature cannot use "share" state without non-local "mechanism" (which isn't really that surprising)
I don't think Bell use the word share, because he wasn't confuse about what a unique QM state is. The "paper" of the OP is more than confuse about its "ontology" (and the time evolution they purport to use (which time ?))
Boing3000 said:
I see nothing about single electron interference in that experiment (nor what a single electron having "interference" would mean)Which seems to me to be pretty standard ensemble QM observation.
This is off-topic here but this is what I should heve cited
https://www.ifi.unicamp.br/~cabrera/teaching/aula 8 2010s1.pdf
from Am. J. Phys 57(2) 1989
What I am saying is the consensus way that Bell's theorem is understood.
What we know by observation in an EPR type experiment is that Alice's and Bob's results are correlated: If we let P(A,B|a,b) be the probability that Alice will get result A and Bob will get result B, if Alice's setting is a and Bob's setting is b, then to say that the results are correlated is to say that the probabilities don't factor:
P(A,B|a,b) \neq P(A|a) P(B|b)
A local hidden-variable model for this correlation would be given by a set \Lambda of possible values of some hidden-variable \lambda, together with probability distributions P(\lambda), P_A(A|a, \lambda), P_B(A|b, \lambda) such that
P(A, B) | a, b) = \sum_\lambda P(\lambda) P_A(A | a, \lambda) P_B(B | b, \lambda)
(where the sum would be replaced by an integral if \lambda is a continuous variable).
Bell proved that for the correlations predicted by QM for the EPR experiment, there is no local hidden-variable model that makes the same predictions.
(Bell's argument is not directly in terms of probabilities, but in terms of expectation values: E(A,B | a, b). This is the expectation value of the product of A and B. Since the results A and B are always \pm 1, This is related to the probabilities through
E(A,B | a, b) = P(+1, +1|a,b) + P(-1, -1|a,b) - P(+1, -1|a,b) - P(-1, +1|a, b).)
Locality comes into play in the assumption that the probability of Alice's result depends only only \lambda and a, while Bob's result depends only on \lambda and b.
Bell explicitly gives a toy example of such a local hidden variable model that has some features with EPR, but does not agree in detail.
His example is this (paraphrasing)
  • Model spin-1/2 particles as spheres, where one hemisphere is colored red and the other is colored black.
  • Bob's and Alice's particles always have opposite colorings.
  • When the spheres are produced, the axis running from the center of the red region to the center of the black region is
  • When Alice or Bob measures the spin along axis a, she gets +1 if a is in the red hemisphere of their respective spheres, and -1 otherwise.
This model is a hidden-variables theory that agrees with EPR in two respects:
  1. Alice and Bob always get opposite results if they measure along the same axis.
  2. The results are always \pm 1
  3. For each measurement taken separately, the results are equally likely to be +1 or -1.
But the details of the correlations when Alice and Bob measure along axes that are not aligned do not agree with EPR.
I share a hidden variable with you if the hidden variable has the same value for both of us. If we get together and decide that our club's secret pass phrase is "bologna sandwich", then we share that secret. The assumption of locality is that the only way that you and I can be guaranteed to share a secret is if we have a common past: The value of the secret was determined at some point in the intersection of our backwards lightcones.
It occurs to me that you might be thinking of two people sharing a variable in the sense that even if the variable changes value, it will change in the same way for both people. For the purposes of Bell's theorem, the relevant hidden variables are the initial state of the twin pair. He's not considering a model where the hidden variable changes with time.
OK, but that consensus is not "No, it's not nonlocal if it is only shared by particles with a common past."
Which boils down to the shared(entangled) hidden property (here correlation) is non-local. The OP paper (as well as Bell's one) is all about hidden variable.
Indeed, and that's even more powerful than probability (which in my view is a subset of expectation value)
More specifically that is is the same \lambda. And that's the thing. He specifically specified that no more assumption as to be applied to that "hidden variable" at the bottom of the first page. Locality comes into play because locality imply a copy of \lambda. In math term expressison (2) have to \lambda at different "site"...
Indeed, an other toy model are easy to build even to mimic full EPR setups... you just have to implement non-locality.
That's incorrect. "Same value" means two identical copy of that value. In my example, having two identical (cloned) house does not mean we share a house.
Sharing a hidden variable is a precise term that Bell exclude in precise math. There is two \lambda in equation (2) and that's what imply locality.
That's not only my particular thinking. It is what non-locality means. It doe not mean identical copies magically linked by spooky FLT. It means one value all along, it means total commutative. And it isn't concerned by Bell's proof, because...
As you said, the prove does rely on copy(locality) of \lambda being unable to reproduce QM outcome.
stevendaryl said:
He's not considering a model where the hidden variable(s) changes with time
Nor does it exclude it ... nor does it make any differences... (I added an "s" which made all the difference)
Two local hidden variable which in Bell terms "can be anything" won't do the trick, a (obviously) non-local one would...
It's possible that our disagreement is merely over terminology/definitions. In Bell's argument the shared hidden variables were assumed to describe the initial state of the twin pair. If the correlations can be explained in terms of that common value, then we have a local hidden variables theory.
As I said, Bell's theorem did not consider time-dependent hidden variables, because for his purposes, there is no reason to.
Bell's proof was about local hidden variables. He was not making any kind of claim about nonlocal hidden variables. He acknowledged from the start that if you allow nonlocal interactions, of course you can reproduce the predictions of EPR. This can be demonstrated either using the Bohm interpretation, or the "measurement collapses the wave function" interpretation. His proof was a proof about local hidden variables, and for you to bring up nonlocal hidden variables seems completely irrelevant.
From the OP paper:
We affirm that the evolution function F(λ,t) must satisfy a condition we call factuality. Mathematically, this condition is no news: for any given function, different outcomes of the function must come from different inputs. So, once the values of hidden variable and time are given, our function F(λ,t) can only acquire a certain value (oA,oB). Physically, this is the factuality condition: if a system evolved in time (t0→t1) to a particular state, it is because only this state was accessible to it given the initial condition (λ,t0) and, therefore, different states at time t1 must come from different values of hidden variables λi. This is only a consequence of determinism.
In our view, non-local correlations emerge from the deterministic evolution of a shared hidden variable between two components of an ontological pair. Entanglement arises every time two (or more) physical entities share hidden variables. This suffices for the time being, and for the example we work below. In what follows, we will analyse the emergence of Bell’s inequality within our proposed description of reality.
They constructed their description of "deterministic evolution", which specifically requires one and only one possible outcome for a specific set of inputs. And those inputs would "complete" QM in their view. Heard that before? Everything about their model is essentially what Bell contradicts. They also reference PBR, which I think pretty much refutes exactly what is stated above. They manage to hand-wave everything away!
It is also interesting that their model is flatly contradicted by entanglement experiments in which the entangled particles have never been in causal contact, i.e. they never evolved from a common set of local hidden variables. Such as this experiment, in which the entangled particles are 1.3 km apart and the selection of measurement basis is made under strict locality conditions as well:
https://arxiv.org/abs/1508.05949
Likes bhobba, kurt101 and Mentz114
Yes, the proposed model is superdeterministic. I believe this is the principal point that makes it uninteresting.
I don't think that this is a problem because QM states do evolve deterministically. Bell also explains, in his famous 1964 paper, that hiddden variables may be considered as initial values that evolve dinamically with time.
DrChinese said:
From the OP paper:
Is your comment that “they never evolved from a common set of local hidden variables” misleading? My understanding of the experiment so far is that the experiment selects the results that A and B had in common after learning at C whether the photons from A and B had some kind of correlation.
Also, in this experiment are the ZPL and PSB photons considered entangled?
facenian said:
Yes, the proposed model is superdeterministic. I believe this is the principal point that makes it uninteresting.I don't think that this is a problem because QM states do evolve deterministically. Bell also explains, in his famous 1964 paper, that hiddden variables may be considered as initial values that evolve dinamically with time.
They might, true, but they don't. No variation in time is discernible by the results - and it easily would be in any entanglement. The superposition follows a conservation rule. So there is no local time evolution, which is what the OP imagines.
kurt101 said:
1. Is your comment that “they never evolved from a common set of local hidden variables” misleading?
2. My understanding of the experiment so far is that the experiment selects the results that A and B had in common after learning at C whether the photons from A and B had some kind of correlation.
1. No, definitely not. :smile:
2. An examination at C is performed, yes. However, A and B have no common light cone (in the sense that their prepared state never existed in a common light cone).
3. I don't think they are entangled, but I am not really sure about that.
Likes kurt101
As I said, I don't really understand what the authors are saying, but a loophole in Bell's theorem that they may be exploiting is differential detection. I assume that this loophole has been closed by experimentalists, but I'm not that familiar with the research:
Suppose that associated with every twin pair is a pair a,b such that:
  • If Alice chooses her detector orientation to be \pm a (within a certain level of accuracy), then she will deterministically get \pm 1 (direction a produces +1 and direction -a produces -1).
  • If she chooses any other orientation, she will not detect a particle at all.
  • If Bob chooses orientation \pm b, he will get \pm 1 deterministically.
  • For any other orientation, he will fail to measure anything at all.
If you ignore mismatches where only one or the other experimenter detects a particle, then the remainder could very well violate Bell's inequality.
Such an explanation would imply an upper bound on the detection efficiency, which probably has been ruled out by experiment, but I don't know.
Likes DrChinese
stevendaryl said:
1. As I said, I don't really understand what the authors are saying, but a loophole in Bell's theorem that they may be exploiting is differential detection. I assume that this loophole has been closed by experimentalists, but I'm not that familiar with the research:
2. If you ignore mismatches where only one or the other experimenter detects a particle, then the remainder could very well violate Bell's inequality.
1. I interpret this to mean that there is not rotational symmetry in the detection efficiency. Although I have not seen that specifically mentioned, it would be pretty obvious if it occurred. Certainly the raw counts I have seen in many experiments do not imply that there are differences in detection in any way related to the angle settings.
2. Sure, a Bell inequality violation could occur if there was some bias in the sample of events. There have been a number of experiments (such as the one I cited) in which *all* events are counted, and fair sampling need not be assumed. That's the equivalent of saying a non-detection is counted on the side of "local realism".
The authors themselves say explicitly in the conclusion that they are exploiting the superdeterminism loophole:
Our factuality assumption implies a common cause on the detectors and particle creation process, which is encoded in the hidden variables. This exploits the so-called freedom of choice loophole, which appears when questioning independence of the detector settings, from the hidden variables that emerge at the creation of the entangled states [19].
In the context of Bell's theorem, "freedom of choice" means the same thing as "no superdeterminism". Earlier (page 5 of the ArXiv version) they say explicitly that not only the spins of particles but also the orientations of the detectors are determined by the hidden variable ##\lambda##:
So, given ##\lambda \in \Lambda## and the time of measurement, ##t_{1} \in \mathbf{R}##, $$\mathcal{F}(\lambda, t_{1}) = (\mathbf{o}_{A}, \mathbf{o}_{B}) \,,$$ where ##\mathbf{o}_{A}## and ##\mathbf{o}_{B}## are the spin projection orientations of each component of the pair, and they themselves are functions of ##\lambda## and ##t_{1}##, ##\mathbf{o}_{A}(\lambda, t_{1})## and ##\mathbf{o}_{B}(\lambda, t_{1})##. Note that these functions are absolutely deterministic, and a direct consequence of this is the fact that the orientation of the detectors is also encoded in ##\lambda##. There is no what would have happened if the detector had not been in such and such orientation? The detector will have only one true orientation, determined by all the previous conditions accessible to it. This is what a truly deterministic scenario entails. A detector in a different orientation will have different values of ##\lambda## at all earlier times.
Of course, whether it is mathematically possible to violate Bell inequalities by exploiting this loophole is a different question from whether it is a good way to understand the violations of Bell inequalities seen in experiments in practice. I didn't see any exploration of the latter in the paper.
Likes DrChinese
  • #31
In above superdeterministic model what would the expression be for all possible permutations : given 360 settings at A and B that are encoded in λ . Then that would be 3602 for detectors. Then how would encoded spins in λ at A and B be incorporated ?
  • #32
It's not difficult to show that you can you can potentially "explain" any correlations by exploiting the superdeterminism loophole. For example, take ##\lambda## to be of the form ##\lambda = (r, s, \boldsymbol{a}, \boldsymbol{b})## with ##r, s \in \{-1, +1\}## and where ##\boldsymbol{a}##, ##\boldsymbol{b}## are unit vectors in ##\mathbb{R}^{3}##. Then set $$\begin{eqnarray}
\boldsymbol{o}_{\mathrm{A}}(t_{1}, \lambda) &=& r \cdot \boldsymbol{a} \,, \\
\boldsymbol{o}_{\mathrm{B}}(t_{1}, \lambda) &=& s \cdot \boldsymbol{b} \,, \\
\rho(\lambda) &=& p(r, s | \boldsymbol{a}, \boldsymbol{b}) q(\boldsymbol{a}, \boldsymbol{b}) \,.
\end{eqnarray}$$ Then you can make ##q(\boldsymbol{a}, \boldsymbol{b})## be whatever probability (or probability density) you want that measurements along the axes ##\boldsymbol{a}## and ##\boldsymbol{b}## will be chosen, and make ##p(r, s | \boldsymbol{a}, \boldsymbol{b})## whatever probability you want that the result of measuring along axes ##\boldsymbol{a}## and ##\boldsymbol{b}## will be ##(r, s) \in \{++, +-, -+, --\}##.
They don't have a model in any really useful sense though or discuss the magnitude of the task that would be. For example, suppose I planned to do a Bell experiment tomorrow in which two humans will (rapidly) choose the measurements to be done in the course of the experiment. In order for them to say in advance what their function ##\mathcal{F}(t_{1}, \lambda)## was they would need a physical theory that was comprehensive and detailed enough to predict not only what the spins are going to be but also human behaviour -- what measurements the humans are going to choose to do -- so that they can explain why they decide to do the right measurements at the right times for the experiment to show a Bell violation.
  • #33
I don't think this is correct since A and B must share a common past light cone. That is what locality meas and that is why they share the same value of lamda.
  • #34
Other than the fact that all experimental setups on this planet could be considered to exist in a common light cone: No, you are incorrect.
My point exactly is that the cited experiment does not have the possibility that the measurement settings could be part of any local set of hidden variables. There was never any contact between Alice and Bob (A & B). And there was no common source for the entangled particles. The entanglement occurs afterward, at C. Not before - as in many Bell tests.
Now wle is saying that the OP paper exploits the superdeterminism loophole. I'm not entirely sure about that, but there is plenty of indicators that wle is correct. The problem is that a paper touting superdeterministic ideas should be so labeled in the abstract. That it would not be borders on intentional misdirection.
In fairness: I consider superdeterminism to up there with witchcraft and conspiracy theories when it comes to considering it as science. But that is stuff for a different thread. :smile:
Likes Mentz114
  • #35
Thar's right measurements are spacelike separated
This is not correct. You may want to check Bell's "The theory of local beables ". Here he explains the concept of local causality and draws a nice picture(fig.3) where the common causes responsable for the correlations are seen to lie in the overlap region of their past light cones. This is how the correlations are supposed to be locally explained by the hidden variables.
Now wle is saying that the OP paper exploits the superdeterminism loophole. I'm not entirely sure about that, but there is plenty of indicators that wle is . :smile:
Threre's no doubt @wle is correct. It is explicitly stated in the paper.
  • #36
After this discussion here are two conclusions:
1. The paper is not very interesting because it relies on superdeterminism
2. The authors issue a wrong statement when saying that double slit experiments can be interpreted as an statistical effect.
Thank you guys!
  • #37
Sorry, you are mistaken (excepting of course that all experiments on Earth can be said to exist in a common light cone.
The reason is that the experiment I cited is NOT causally constructed like most Bell tests. The cited experiment had never been performed while Bell was alive, not sure it had even been conceived at that time. There have now been many experiments in which entanglement occurs without any causal contact between the entangled particles. So it makes no sense to construct a paper around an explanation of entanglement that ignores experiments such as what I cited. They have basically ignored decades of experimental work.
  • #38
Thank you guys!
1. Assuming everyone agrees the OP article is intended as a superdeterministic explanation of Bell, I would call such a paper a scientific sham. IMHO there's no science hiding there.
  • #39
Well from this complete paper by the authors : https://arxiv.org/abs/1605.0849T3
They are intending a deterministic explanation for the correlations:" In our view non - local correlations emerge from a deterministic evolution of a shared hidden variable between two components of the ontological pair. And this also agrees with @A. Neumaier and his definition of Extended causality: *
"Joint properties of an extended object depend only on the union of the closed past light cones of their constituent parts and can influence only the union of the closed future cones of their constituent parts."
* Can this definition of Extended causality apply to space like separated experiments ?
  • #40
Sorry but I'm suspicious about your assertion. I agree that the precicion to test Bell theorem has been increasing with time, however you are saying that the basic concept of entanglement that Einstein and Bell were talking about has become obsolete rendering Bell's proofs inaplicable.
Since I'm not an expert I can not tell but I would like hear some other opinion on this point.
Likes kurt101
  • #41
Nothing about Bell's Theorem has changed or diminished in the slightest. If you think that's what I am saying, please reconsider. What you were quoting is something else written by Bell about a specific type of Bell test. Bell tests have advanced greatly since to eliminate even more "loopholes". Some of those loopholes are detection/fair sampling and locality, which are simultaneously eliminated in this test. Also, and relevant to the OP's claims:
"Our experiment already excludes all models that predict that the random inputs are determined a maximum of 690 ns before we record them..."
That is in addition to the fact that Alice and Bob are not in causal contact. So there are no shared local variables related to the particles being measured. And the measurement settings themselves are determined independently by Alice and Bob a very short time before their measurements, far too short to have been communicated from one to the other.
That's quite a lot of physics for even a superdeterministic hypothesis to overcome. :smile:
  • #42
Here's a question for Dr. Chinese, who is more familiar with these tests of entanglement. The usual way that a Bells-Theorem-violating twin pair is produced is something like the figure below:
There is some kind of decay process that produces an entangled particle/antiparticle. (I drew it as a photon decaying into an electron/positron pair, which actually isn't possible, but maybe you could substitute a \pi_0 meson to make it plausible. How the particles are produced are not important for this discussion.)
Now, let's vary the experiment by producing 4 particles, as shown in this figure:
In this figure, we produce two sets of correlated pairs. The question then is: Is there something that can be done to the two particles in the box--some kind of measurement maybe--that forces the remaining two particles to be entangled? Maybe if you measure the total spin of the two particles in the box, and find them to have total spin zero, then that will force the other particles to be anti-correlated?
If an experiment like this were possible, then it would be a way to produce entangled particles that have no common past. That would seem to be an even simpler argument against local hidden variables than Bell's theorem--the correlations can't possibly be explained in terms of local hidden variables if they never met in the past to share that hidden variable.
Likes DrChinese
  • #43
Entangled quantum objects need not have a common past light cone, nor a common future light cone. This can be seen by the existence of entangled pairs where the sub-components have never co-existed at any point in time.
The point to recognize here is that the technology today has advanced so far that the old ways of looking at entangled pairs is outmoded. Formerly, entangled pairs arose from a common source. That provided us an easy to picture model of entanglement which is intuitive (to some degree). Everything apparently moves forward in time:
(Future)
Alice: V :Bob
(Past)
However, entangled pairs can be created from fully independent sources as well. I.e. 2 lasers in different spatiotemporal regions. Those objects are then entangled via entanglement swapping at a third spacetime point. This is done in such a way as the spacetime cones of the swapping components is also independent. In fact this can be done after the other particles no longer exist, just to drive the point home.
Now, if you choose to define the extended object as being the region defined by ALL of its components at all times they exist, then the definition above is fine. However, the resulting causal diagram has arrows in BOTH directions of time. It looks something like (Chris would be in the middle, not labeled below):
(Future)
Alice: W :Bob
(Past)
Having those arrows going both ways in time is a problem for most people. So define it as you see fit.
  • #44
Ha, I just posted something like your diagram, except yours is much better...
  • #45
And the answer is a big YES. :smile:
Inside the box, you perform what is referred to as a Bell State Measurement (BSM). Some of these project Alice and Bob into an entangled state. When that happens, Alice and Bob are perfectly correlated* AS IF they were the pair originally entangled. That is called entanglement swapping.
https://arxiv.org/abs/quant-ph/0201134
https://arxiv.org/abs/0809.3991
So this is what I have been referring to in some of my prior posts. Of course, "conspiracy" theories will evolve even under these scientific challenges. However, the resulting (super)deterministic quantum theories becomes (laughably :smile: ) untenable with these scenarios. If someone were to postulate a specific way they worked, it could easily be falsified.
*Or anti-correlated, depending on the result of the BSM. Note that the BSM results are themselves random.
  • #46
https://arxiv.org/abs/0809.3991*Or anti-correlated, depending on the result of the BSM. Note that the BSM results are themselves random.
Good. Then as I said, in some sense, it seems that Bell's inequality is almost unnecessary to demonstrate the impossibility of a local hidden-variables theory that could explain the correlations, since is there is no way for the entangled particles to acquire a common hidden variable.
Likes DrChinese
  • #47
The Hilbert space of the full system is of the form ##\mathcal H = \mathcal H_1 \otimes \mathcal H_2 \otimes \mathcal H_3 \otimes \mathcal H_4##. It can be proven mathematically that if the observables of each particles commute in spacelike separated regions (which is true in the standard model), then the reduced density matrix on ##\mathcal H_1 \otimes \mathcal H_4## is completely independent of what you do to the particles in the box (##\mathcal H_2 \otimes \mathcal H_3##). It's an easy undergrad exercise. So no physical interaction in the box can physically entangle particle 1 &4. However, what you can do is produce entangled statistics by post-selecting events based on information that is obtained from particles 2 & 3. This is what's called entanglement swapping. It's not a physical process, but rather an operation that is applied to measurement data that has already been recorded after it has been recorded.
  • #48
I would dispute such characterization. No one can be sure that the Bell State measurement of 2 & 3 does not cause a change to 1 & 4. The experiment must be viewed as a total context, and identifying the causal agents when there is quantum nonlocality is not really possible. This is same kind of issue as you have with a quantum eraser. Does the eraser cause a non-local change?
My point is not to start an argument about this, but to say that causality cannot be identified clearly unless you start with a specific interpretation. And we know where interpretations will take us... :smile:
  • #49
DrChinese said:
I would absolutely dispute such characterization. No one can be sure that the Bell State measurement of 2 & 3 does not cause a change to 1 & 4.
But depending on the spacetime separation, the measurements of 2&4 can be spacelike separated from the subsequent measurements of 1&4. So I can't see how there could be a local hidden-variables explanation.
I'm only saying that the experiment seems incompatible with a local realistic explanation.
Likes DrChinese
  • #50
Oh, I agree completely. These experiments are even stronger arguments against local realistic explanations than the original Bell types.
And just to be clear: when I say the the Bell State Measurement of 2 & 3 projects 1 & 4 into an entangled state, I don't mean that it is doing so in local realistic terms. This is strictly a quantum nonlocal description. This is the usual description given by authors of these papers. Note: You could also say that the measurement of 1 & 4 casts 2 & 3 into a Bell State.
