Is Below Zero Kelvin Possible in Outer Space? Curiosity and Scientific Theory
  • Thread starter jaredmt
  • Tags
    Zero
In summary, according to current understanding, it is not possible to cool an object to 0 K, and it is also not possible to get below 0 K from a practical perspective.
jaredmt
121
is this possible anywhere?
i know 0 kalvin is the lowest temperature possible that we've been able to attain. but is it possible that in outerspace where there is no heat from sun, that it gets below zero kalvin?
im just curious. I am not sure wether this was "proven" to be the lowest possible temp or just the lowest temp we've been able to get. because i do know that no matter how hard you try to take heat out of something, more heat will just keep going back into it at the same time
Chemistry news on Phys.org
According to current understanding, no temperature below 0 K exists. Also, it is not possible from a practical perspective to cool an object to 0 K (the process would take an infinite amount of time). The lowest humans have achieved is less than one billionth of a Kelvin, far colder than interstellar space, which is approximately 2.7 K.
Yes, we've never been able to get to 0K. Space is at about 2.7K like Mapes says because of the Cosmic Background Radiation.
The reason we can't get to 0K is because of statistical mechanics, basically.
http://en.wikipedia.org/wiki/0K
Yes, it's possible, in a Laser system, for example.
Temperature can be defined as the partial derivative of energy with respect to entropy; in a system like a Laser, there is "population inversion" so entropy *decreases* instead of increase, when energy increases, so the absolute temperature is negative.
As Norman Ramsey has pointed out, objects with negative temperature are not colder than absolute zero, but instead hotter than anything else. Heat energy will always flow from a inversion state to a state that is closer to equilibrium; this is the characteristic of a high temperature, not a low temperature.
As lightarrow points out, the statistical-mechanical origin of 'temperature' can lead to counterintuitive results- for example, a population inversion in a two-state system corresponds to negative temperatures.
0 K should be considered a thermodynamic limit.
'0 K' is not acheivable due to the laws of thermodynamics, and it is also not true that 'all motion ceases at 0 K' due to the zero-point energy.
ok that is confusing that -k is actually hotter than +k. there are actually mechanical tests where they created a negative temperature? and it was hotter? that's strange
Probably better to think of it as a mis-use of the concept of temperature.
There are areas of solid state physics where you treat an electron as having negative mass - the maths works and you get the right answer - but it's not necessarily 'real'.
o. so basically we just arent technologically advanced enough to get the right formula to achieve the real -k (if it exists)
How did you conclude that from the responses? It's not a technological barrier.
No I mean that negative temperature in a laser inversion isn't real it's just a convenient mathematical trick.
It's like being overdrawn at the bank, you don't really own 10 negative dollars - it's just easier to do the sums that way.
Related to Is Below Zero Kelvin Possible in Outer Space? Curiosity and Scientific Theory
What is "Below zero Kalvin"?
"Below zero Kalvin" is not a scientifically recognized term or concept. It is possible that it may refer to the measurement of temperatures below absolute zero, but this is currently only a theoretical concept and has not been achieved in laboratory conditions.
What is absolute zero?
Absolute zero is the lowest possible temperature, equal to 0 Kelvin or -273.15 degrees Celsius. At this temperature, all molecular motion stops and it is considered the coldest temperature possible in the universe.
What is the significance of absolute zero?
Absolute zero is significant because it is the point at which all molecular motion stops, providing a baseline for temperature measurement and the basis for the Kelvin temperature scale. It also has important implications for understanding the behavior of matter at extremely low temperatures.
Can absolute zero be reached in reality?
No, absolute zero cannot be reached in reality as it is a theoretical concept. However, scientists have been able to reach extremely low temperatures close to absolute zero in laboratory settings using techniques such as laser cooling and magnetic cooling.
Why is it impossible to reach absolute zero?
It is impossible to reach absolute zero because it would require all molecular motion to stop completely, which violates the laws of thermodynamics. Additionally, as objects cool, they release heat energy which keeps them from reaching absolute zero.
  • Astronomy and Astrophysics
  • Thermodynamics
  • General Discussion
