How Does Mass Affect the Fabric of Space-Time?
In summary: Earth. The planets orbit because they have more mass than the other objects, and their gravity pulls them in towards the center of the Milky Way.
Paramedic_Nerd
I'll ask that you forgive me if my question seems to "basic" or simple for some of the more professional posters. I am simply a physics/cosmology enthusiast who has been captured by it all since I was a child, however, there is one issue that as I continue to learn more is bothering me.
I am of course familiar with the illustration that depicts a body of mass depressing a region of space time as described by the "grid" and I understand this to be the easiest way to depict this phenomena. My questions are as follow:
1) Does a body of mass not "pull" or "depress" space time in ALL directions, indicating that the visual representation or illustration most commonly use is merely one perspective on one plane of one dimension at the time of observation?
2) This question may be nullified by the answer to the first, but presuming space time is affected by mass the way the common illustration describes, I often ask; What about the other side of that curvature? If the "depression" of space time holds bodies in place ( moons and other satellites), then would the "peak" or convex portion of space time not repel bodies?
3) Also dependent on the answer to question number one, if space time is in fact bent or warped in ALL directions; Why do the planets of our solar system orbit on a seemingly level plane? Why should it be there are no planet or bodies that obit perpendicular, or any other angle really, to Earths' orbit.
I thank you for your time and patients as you read and consider responding. I hope to find or create a network of peers, who despite my apparent or preserved ineptness on some subjects, enjoy sharing their knowledge and experiences. Through years of recreational researcher and haphazard investigations of my own, I continue to build on a solid foundation of basic understanding. With the capacity to learn, the ability to accept and understand as well as the innate desire to know, the need to know, I look forward to exploring through both imagination and intellect the farthest reaches of physics, the cosmos and all that is in between and beyond.
Paramedic_Nerd said:
I am of course familiar with the illustration that depicts a body of mass depressing a region of space time as described by the "grid" and I understand this to be the [STRIKE]easiest[/STRIKE] most misleading way to depict this phenomena.
Fixed it for you :smile:..
Seriously, kidding aside, that picture is seriously misleading. If you search this forum for "rubber sheet analogy" you'll find some posts explaining why, and you may also come across member A.T.'s somewhat excellent video showing what's really going on.
It's not a "pull" or a "depression", it's curvature. One way of imagining it: If you and I start one mile apart on the equator and both walk due north in a straight line, we'll become conscious of a force that is inexorably shoving us towards one another until we collide at the north pole. What's really going on, of course, is that on the curved surface of the Earth parallel lines do intersect, although they don't on a flat surface. (This analogy is misleading for other reasons, but it's still a lot better than the rubber sheet). Note that it is space-time that is curved, not just space - the "paths" of two objects that are ostensibly at rest and subject to no forces can still converge or diverge because they're still moving forward in time.
The "depression" isn't what holds the body in place, and that may be the most misleading aspect of the rubber-sheet analogy. There's no depression, no "other side".
There are many such objects in such orbits - they just happen not to be as big as the planets. The planets all ended up in more or less the same plane (but the deviations for some of them are still quite large) just because of the initial conditions under which the solar system formed.
Thanks very much. You have provided some excellent clarification as well as some thought provoking jump off points for me to further investigate. I look forward to hearing from you again regarding future questions and concerns.
Yes, it is just 2D spatial geometry at constant time, which is a subset of 4D space-time. The distortion of the time dimension is not shown there. 2D space-time looks more like this:
https://www.youtube.com/watch?v=DdC0QN6f3G4
And on a larger scale:
http://www.adamtoons.de/physics/gravitation.swf
There is no "other side", it is a one sided surface. Only the geometry within the surface matters. So it doesn't matter if you draw it deformed down or up.
See also:
http://www.physics.ucla.edu/demoweb..._and_general_relativity/curved_spacetime.html
The space-time geometry is spherically symmetrical. You have the same 2D space with a dent for every plane that goes through the center. And you get the same 2D space-time along every radial line through the center. As Nugatory said, the alignment of orbit planes has to do with initial conditions and the way a solar system forms.
I appreciate your enthusiasm for physics and cosmology. The concept of bending of space and time is a fundamental aspect of Einstein's theory of general relativity, which has been extensively tested and confirmed through various experiments and observations.
To answer your questions:
1) Yes, a body of mass does indeed "bend" or "depress" space and time in all directions, not just in one plane or dimension. The common illustration is simply a simplified representation to help visualize the concept. In reality, the bending of space and time is a much more complex and multi-dimensional phenomenon.
2) The other side of the curvature is not necessarily a "peak" or convex portion of space and time. It is important to remember that the curvature of space and time is not a physical object that can be seen or touched. It is a mathematical concept that describes the way space and time are affected by the presence of mass and energy. So, the other side of the curvature may not necessarily "repel" bodies, but rather, it is a continuation of the curved space-time fabric.
3) The reason why planets in our solar system orbit on a seemingly level plane is due to the conservation of angular momentum. When the solar system was formed, the protoplanetary disk from which the planets formed was rotating in a specific direction. As the planets formed, they inherited this rotation and continued to orbit in the same direction and on a similar plane. Any deviation from this plane would require a significant amount of external force or influence.
I hope this helps to address your questions and I encourage you to continue exploring and learning about the fascinating concepts of space and time. As scientists, we are constantly pushing the boundaries of our understanding and there is always more to discover and learn.
What is the concept of "bending" in space and time?
The concept of bending in space and time refers to the distortion of the fabric of the universe caused by the presence of massive objects, such as planets or stars. This distortion is a result of the gravitational force exerted by these objects, which causes space and time to be curved around them.
How does the bending of space and time affect the movement of objects?
The bending of space and time affects the movement of objects by altering the trajectory of their paths. Objects moving through curved space-time will follow a curved path, as if they are being pulled towards the source of the gravitational force. This is known as the curvature of space-time.
Can we physically observe the bending of space and time?
Yes, the bending of space and time can be observed through the phenomenon of gravitational lensing. This occurs when light from distant objects is bent as it passes through the curved space-time around massive objects, creating a distorted image of the object. This effect has been observed and confirmed by astronomers.
How does Einstein's theory of general relativity explain the bending of space and time?
Einstein's theory of general relativity explains the bending of space and time as a result of the presence of mass and energy. According to this theory, objects with mass create a curvature in space-time, and the amount of curvature depends on the mass and energy of the object. This theory has been extensively tested and has been shown to accurately predict the bending of space and time.
What are the potential implications of the bending of space and time?
The bending of space and time has several potential implications, including the understanding of gravity, the behavior of light, and the structure of the universe. It also has implications for space travel, as objects must account for the curvature of space-time in their trajectories. Additionally, the bending of space and time could potentially be used for time travel, although this is still a topic of much debate and speculation among scientists.
