Best practice for large electric motors
Determining the cost-effectiveness of shutting down large electric motors during breaks versus leaving them idling depends on their load; fully loaded motors can waste significant energy, potentially costing around $60 per lunch hour. The discussion highlights that if motors are not loaded during breaks, shutting them down may be more efficient. Concerns about motor efficiency lead to inquiries about "phase aligners," which are devices that may improve power quality but have mixed reviews regarding their effectiveness. It's crucial to monitor the power factor on electric bills, as a poor power factor can incur additional charges, and it should be clearly indicated on the bill. Understanding these factors can help optimize energy usage and reduce costs in manufacturing operations.
justaguywa?
This may not be the place to ask this question, but I can't seem to get a good answer anywhere else...I have a manufacturing company. I am on a 3-phase demand meter. I'm trying to figure out if it is more cost effective to shut all the electric motors down during breaks and lunch and restart or just leave them running "idling" during these times? The motors are 2 - 100 HP, 4 - 75 HP, and 4 - 50 HP.
The other question I have is about motor efficiency - I've had a salesman come by and talk to be about "phase aligners" (Don't really know what they are, but I'm guessing some sort of capacitor that "cleans up" the inbound electricity). Anyone know anything about these and if they are worth fooling with?
For the first question, it depends a little on what these motors are doing, but if they are fully loaded but doing something unnecessary, they are consuming a lot of energy that could be saved. About $60 per lunch hour.
For the second, there are some products that advertise various power cleaning capabilities. I tested one once on a compressor and it didn't seem to do much. What you do really want to make sure of, though, is that your power factor isn't bad enough that the electric company charges you for it (it should be clear on your bill). If it is bad, you should have an engineer select and a contractor install a capacitor bank to correct it.
Welcome to PF - there's no better place for such a question!
Thanks for the response.
The motors are not loaded during these times - I thought it would be better to shut them down, but the practice has always been to leave them running - someone told a previous supervisor that because of the demand meter, it was better just to leave them running than to restart them after breaks (15 minutes X 2) and lunch (30 minutes). Each motor is started independant of the other, so it's not like they are all restarting at once.
You say that there should be something on my bill if the power factor is bad? Where should I look for that. I'm sure every power companies bill is different, but is there a certain nomenclature that would show up or stand out if I have a problem?
Again thanks for the information.
For power factor, it should just say power factor, followed by a number between 0.5 and 1.0. The detail of the bill shouldn't be very long...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
