How Accurate Can Static Pressure Measurement Be?
Static pressure measurement accuracy can be achieved with appropriate sensors and setups, particularly when measuring before and after a fan. An accuracy of 10 Pa is feasible, which corresponds to 1 part in 10,000 of atmospheric pressure. For differential pressure across a fan, an inclined manometer may suffice, but a mid-level digital manometer is recommended for higher precision. The need for such precision is primarily to accurately determine airflow from a fan curve. Overall, achieving high accuracy in static pressure measurement is possible with the right tools and methodologies.
dries
I wondered how you can measure (static) pressure, with an as high as possible accuracy. Could you share your experience about which sensor and setup you allready used?
I would like to measure the static pressure before and after a fan with an accuracy of 10[Pa]. Do you think this is possible?
Do you mean 1 part in 10,000 of atmospheric pressure? Why the precision?
If you are trying to measure the DP across the fan you might manage it with an inclined manometer.
Yes I mean 1/10000 of atmospheric pressure, the accuracy is needed to determine the flow from a fan curve.
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
