Can You Explain Beta Minus Decay and its Relation to Neutrinos?
  • Thread starter Thread starter hasnain721
    Beta Decay
hasnain721
[SOLVED] beta minus decay?
Hi,
Here is a question from beta minus decay which i could not understand :
http://img360.imageshack.us/img360/2512/59060072re9.jpg
I could do the first bit but not the second. I believe that it has something to do with neutrinos and missing energy but i am not 100% sure about it.
Thanks.
hasnain,
Beta decay involves the transition of a parent nucleus into a daughter nucleus with two sideproducts; an electron and an antineutrino.
Since the nucleus is so massive, it carries little kinetic energy away from the reaction (it recoils very little), the vast majority of the energy goes into the two sideproducts.
Now let me ask you a question:
If there was only the electron as a sideproduct, would there be a continuous range of energies as we see here?
astrorob said:
hasnain,
hi,
Thanks a lot for replyin astrorob.
As far as the question goes, i believe that if only an electron was a side product them the graph would have been a straight line parallel to the y axis. Is that right?
hasnain,
You are correct. There would be only a small range of energies the electron could carry away and this would manifest itself (essentially) as a straight line at x=0.78.
astrorob said:
hasnain,
Thanks a lot astrorob.
CHeers!
You're welcome.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
