Find the Power of a Bi Convex Lens
In summary, a bi convex lens is a type of lens with two convex surfaces that bulge outward, used for correcting farsightedness and magnifying objects. The power of the lens is measured in diopters and can be calculated using the formula P = 1/f, where f is the focal length. The focal length of a bi convex lens is half of the radius of curvature of its surface. Unlike a plano convex lens, which has one flat and one curved surface, a bi convex lens has two curved surfaces. This difference in shape affects the way light is bent, making each lens useful for different purposes.
Deebu R
67
If the focal length of the bi convex lens is 25 cm then the power of the lens will be?
Since the light striking the lens converges at a point behind the lens will the answer come in positive?
Power of lens D= 1/f
D= 1/25= +0.04 dioptre[/B]
You are using the wrong units in your formula.
Focal length should be in mm?
Or is it meters? Is the answer +4 diopter?
Correct
I see.Thank you for the help rude man and BvU.
FAQ: Find the Power of a Bi Convex Lens
1. What is a bi convex lens?
A bi convex lens is a type of lens that has two curved surfaces, both of which are convex. This means that the lens bulges outward on both sides, and is thicker in the middle than at the edges.
2. How do you find the power of a bi convex lens?
The power of a lens is measured in diopters and is a measure of the lens's ability to bend light. To find the power of a bi convex lens, you can use the formula P = 1/f, where P is the power in diopters and f is the focal length of the lens in meters.
3. What is the focal length of a bi convex lens?
The focal length of a lens is the distance between the lens and the point where light rays converge to form a focused image. For a bi convex lens, the focal length is half of the radius of curvature of the lens's surface.
4. How does a bi convex lens work?
A bi convex lens works by bending light rays that pass through it. The convex shape of the lens causes light rays to converge, which is why it is used to correct farsightedness. It can also be used to magnify objects by bending light rays to form a larger image.
5. How is a bi convex lens different from a plano convex lens?
A bi convex lens has two curved surfaces that bulge outward, while a plano convex lens has one flat surface and one curved surface that bulges outward. This difference in shape affects the way light is bent by the lens, making it useful for different purposes.
