Bicycle Translational Acceleration vs Angular Acceleration
121 replies · 14K views
UMath1 said:
So I did that and this is what I got.
Can I simplify this more? Is there a way I can find the force of the chain solely in terms of the force of the pedal and their respective radii? And likewise, is there a way to find the force of static fricition solely in terms of the force of the chain on the rear gear and the radii of the wheel and rear gear?
When you ask about the force of the chain, are you referring to the force in the upper part of the chain, the force in the lower part of the chain, their difference, or their sum?
Chet
I mean the net force of the upper and lower tensions. Tu-Tl
UMath1 said:
The sum
The vector sum of the tensions in the upper and lower parts of the chain are determined mainly be the preloading of the chain. Prior to riding, the tensions in both sections of the chain are equal, and pulling forward on the rear wheel assembly and backward on the front pedal assembly. When the bike is accelerating, the tension in the upper part of the chain increases, while the tension in the lower part of the chain decreases. However, the lower part of the chain does not go into compression. So, during acceleration, the tensions in the two sections are still pointing in the same direction. In my judgement, the resultant force they impose on the rear wheel does not change significantly, nor does the resultant force they impose on the front pedal assembly. However, the moments that they impose on the rear wheel assembly and on the front pedal assembly change substantially. This is because of the difference in tension that develops between the upper portion of the chain and the lower portion.
Chet
Right. So, is there a way to calculate the difference in the two force based soley on the applied force on the pedal and the radii of the pedal and pedal sprocket? Similarly is a way to calculate the forcd of static friction soley based on this difference of the two tensions and the radii of the rear gear and rear wheel?
I am trying to find proof for why, as haruspex said, the torque of static friction lags behind the torque the chain puts on the wheel.
Earlier my calculation for the force of static friction was: (Tu-Tl)Rg/Rw. But this cannot be the case, because it were you'd have break the maximum force of static friction to get the bike to accelerate.
This is not correct for real bicycles and real chains. For a typical multi-speed bicycle using derailleur gears the bottom portion of the chain is kept at a low and more-or-less fixed tension with a spring-loaded tensioner. You can see several relevant pictures here. https://en.wikipedia.org/wiki/Derailleur_gears
For a three-speed bicycle or a single-speed bicycle pedaled in the forward direction, the situation is similar. The lower chain is essentially slack. The only tension is that resulting from its sag under gravity.
[If the frame were perfectly rigid and the chain were perfectly unstretchable and there were no slack then the situation would be statically indeterminate with no way to determine tension in both chain segments and compression in the frame, even given perfect information about the bicycle. The slack in the bottom chain avoids this difficulty]
What changes when you pedal harder is the tension in the top chain and the compression in the parallel frame member. But the point of application of the force from the frame is exactly at the two axes of rotation -- the hub of the rear wheel and the hub of the crank. So frame compression is irrelevant when computing torques.
You already have that if you are willing to make the reasonable assumption that the rotational inertia of the pedal assembly is negligible.
You already have to equations necessary to determine that.
The lag is probably not very important, but probably depends on how long it takes the tire and chain to deform. But why don't you just ask him?
On what basis do you say this? Did you divide the force of static friction that you calculate by the normal force (which is on the order of the weight of the rider plus bike) and compare the quotient to the coefficient of static friction?
Chet
No, I thought the force the bike wheel applies on the ground could be obtained by a torque balance and hence the equation: (Tu-Tl)Rg/Rw. Then by Newtons 3rd Law the force static friction applies should be the same.
Right. The force of static friction on the bike's rear wheel is given by this formula. Draw a free body diagram for the bicycle as a whole. You have the value for the force from static friction acting at the rear wheel. What other external forces is the bicycle subject to?
static friction of front wheel
I am considering the bike and the rider one system
Any other forces?
UMath1 said:
I can't think of any
Gravity? The normal force of the pavement on the front tire? The normal force of the pavement on the rear tire?
Right. Yes, gravity and normal force, but they cancel out, right?
For some possible calculations, the force from gravity and the normal force on the two tires will cancel out, yes. But if we are trying to be careful, we should list them first and argue that they cancel for the particular calculation we are trying to perform afterward. For instance, we could do a torque balance on the bicycle as a whole to see how large static friction could be before the bicycle pulls a "wheelie". Gravity and the normal forces would be crucial for that.
But back to the problem at hand. You were saying that the bicycle as a whole cannot accelerate unless
We have this free body diagram. It has forces from static friction at the rear wheel, static friction at the front wheel, rolling resistance, air resistance, gravity and the normal force on the two tires.
We can neglect gravity and the normal force on the two tires since they are vertical and we are considering horizontal movement. We can neglect air resistance because it is approximately zero for a near-motionless bicycle in still air. We can neglect rolling resistance as long as the bearings are well oiled and the tires are properly inflated.
Do you agree that we can neglect the force of static friction between pavement and front wheel? Or should we calculate that?
I think it could be neglected for the sake of simplicity. Even if it were a unicycle, you still wouldn't have to break the maximum force of static friction.
So you now agree that the force of static friction does not need to exceed the maximum force from static friction in order for the bicycle to accelerate?
I agree because otherwise you'd run into the original issue of sliding before rolling. However I don't understand why. If the equation is not (Tu-Tl)Rg/Rw, what is it?
I originally thought the equation was (Tu-Tl)Rg/Rw because it would show that a bigger gear would give more traction.
You still have not told us what makes you think that ##(T_u - T_l)\frac{R_g}{R_w}## has to be incorrect.
It has to be incorrect because that would mean that static friction keeps growing as the torque from the chain grows. It would keep growing until it reaches the maximum value. But I have been told repeatedly that reaching the maximum value is unnecessary and that would be "burning rubber".
Also, it brings forth another problem, the equation cannot possibly be applicable after the maximum friction is reached because the friction cannot increase beyond that ppint.
And what makes you think that the torque from the chain grows and grows without bound?
It has to in order give a torque greater than the torque of static friction according to the equation.
I must be missing something. You apply a torque to the pedal, and it causes a corresponding torque to be applied by the ground to the rear wheel (to accelerate the bike). You hold the torque on the pedal constant while the bike is accelerating, and the corresponding torque applied by the ground to the rear wheel stays constant. So, what's the problem?
Chet
In order for the wheel to rotationally accelerate the torque of the chain MUST be greater than the torque of static friction. Based on that equation the only way that can happen is if maximum static friction value is attained. Otherwise, static frictions torque would continue to match the torque of the chain, meaning no angular acceleration.
If you recall, we assumed that the wheel has negligible moment of inertia in order to simplify the calculations. Accordingly, it takes negligible net torque for it to accelerate.
If you want to re-do the calculations with a non-negligible moment of inertia in the rear wheel then we can do so.
If the rotational inertia of the rear wheel is neglected, that equation tells you that the chain torque is equal to the static friction torque. If the rotational inertial of the rear wheel is not neglected, then the chain torque has to be a little higher than the static friction torque, but part of the chain torque is consumed in accelerating the rear wheel, so the static friction torque is the same.
Chet
