What is Big-Oh Notation and How Does it Measure Algorithm Efficiency?
  • Thread starter Thread starter Montag42
    Notation
Big-O notation is a mathematical concept used to describe the efficiency of algorithms, particularly in terms of time complexity. It provides an upper bound on the number of steps an algorithm takes relative to the size of the input, with O(n) indicating linear growth and O(n^2) indicating quadratic growth. For sorting algorithms, it's important to note that O(n log n) is generally faster than O(n^2), and all sorting algorithms require at least O(n) time in the worst case. Simplifying the explanation to focus on "how fast an algorithm runs" rather than "number of instructions executed" can make it more accessible. Including examples and avoiding overly technical language will enhance understanding for a general audience.
Montag42
Hello everyone,
Im doing a relatively simple report/project in my science class (8th grade) on the efficiencies of various sorting algorithms, and I need to explain Big-O notation in a way which is:
1) Easy for a middle aged teacher who's knowledge of a computer pretty much stops at " It uses electricity"
and
2) Is compact enough to be able to put onto a poster board that people don't give up on reading it and walk away.
So what I've come up with so far is
Big O gives the upper bound for time complexity of an algorithm. For example, an algorithm that is O(n) (where n is the number of items to be processed) means that the highest amount of instructions executed is equal to the number of instructions in the algorithm. If an algorithm is O(n^2), that would mean that the highest number of instructions executed is equal to the number of instructions in the program squared.
Any suggestions as to how I could make this better, and (even better) is anything up there wrong?
Technology news on Phys.org
Strictly, what you wrote is wrong. An algorithm that is O(n) takes at most kn steps for some k, which is often greater than 1.
In the context of sorting, to give your readers intuition, I would certainly explain that O(n^2) algorithms are "slow" and that O(n log n) algorithms are "fast".
What is the actual intent? I suspect it's unlikely that explaining Big-Oh notation is the best way to convey the point you're trying to make...
"Big O gives the upper bound for time complexity of an algorithm."
This is a little wordy for a general, non-technical description of big-oh notation. You may want to make it more colloquial. For instance...
"Big O tells you how slow a certain algorithm may be in the worst case."
"Big O notation provides a means for describing the worst-case running time of a certain computational procedure"
etc.
The content is good, though.
"For example, an algorithm that is O(n) (where n is the number of items to be processed) means that the highest amount of instructions executed is equal to the number of instructions in the algorithm."
This is misleading... the wording is good, but the "n" in O(n) has nothing to do with the number of instructions in the algorithm, but the size of the problem. It's generally true that larger problems cause more instructions to be executed. I'd phrase it a little more precisely.
"If an algorithm is O(n^2), that would mean that the highest number of instructions executed is equal to the number of instructions in the program squared."
See above.
I like CRGreatHouse's idea... I would explain why an O(n lg n) algorithm will beat an O(n^2) algorithm (usually... you could provide examples where it didn't, though) and why any sorting algorithm must take at least O(n)...
It's an interesting idea, and I think you could really make it work. Examples will be key. Include examples, if you can.
Right. It would be worth mentioning that sorting algorithms* take at least O(n) time, and that algorithms take at least O(log(n!)) = O(n log n) time in the worst case.
* Assuming they always produce correct output and accept all inputs.
I would not bother with details like 'in the worst case', etc.
What's wrong with simply saying something like:
Big-O notation is a way of describing how fast an algorithm is compared to the size of the task. For instance, in the case of sorting, O(n) means the time taken is proportional to the number of items to sort (n). If it's O(n^2) then it grows as the square of the number of items. And so forth
Saying 'number of instructions executed' is a pretty complicated way of conveying the simple idea 'amount of time'. It's also incorrect by virtue of being more specific than the actual definition, which is in terms of abstract 'steps'. Which can be assumed to be proportional to instructions, but you might as well assume it's proportional to time - which is what people are interested in anyway.
I agree that saying 'time' is probably better than 'instructions', since you need a proportionality constant either way. But I think that the worst-case distinction is important in the case of sorting, where one popular algorithm (you know the one... Hoare's QuickSort) has very different behavior on average and in the wost case.
