Binary transitions, power consumption
The discussion focuses on the power consumption associated with binary transitions in Ethernet devices, particularly the energy required for transistors to switch states from 0 to 1 and vice versa. It highlights that the power needed is influenced by the characteristic impedance of the cable rather than just parasitic capacitance. The characteristic impedance (Zc) of coax cables, which typically ranges from 50 to 125 ohms, plays a crucial role in signal transmission efficiency. Proper termination of the cable at its characteristic impedance is essential to minimize reflections and power losses. Understanding these factors is vital for optimizing power consumption in transmission systems.
phdshine
I'm studying the ethernet devices and the transmission system over cable wire and I'm interested especially on the power consumpiot due to the binary transitions from 0 to 1 and viceversa in the transistors. It is possible to estimate how many WATTS (i thinks nW) are necessary to the device to switch from 0 to 1 or viceversa?
it is due to the charge and discharge of the cable parasitic capacitance?
thank you in advance
You are not driving the parasitic capacitance so much. You are driving into the characteristic impedance of the cable at high frequencies (Zo):
http://en.wikipedia.org/wiki/Characteristic_impedance
Most coax cables range from 50 ohms (e.g., RG-8) to 125 ohms (e.g., RG-63) characteristic impedance Zc. Zc is the square root of the coax inductance per unit length divided by the capacitance per unit length. The parasitic capacitance cannot absorb energy (other than dielectric "tan theta" losses at GHz frequencies). The best cables for long distance signal transmission are Zc~75 ohms with high signal velocity. The cable should be terminated in impedance Zc to minimize reflections. The power losses are in the termination.
Bob S.
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
Hello dear reader, a brief introduction: Some 4 years ago someone started developing health related issues, apparently due to exposure to RF & ELF related frequencies and/or fields (Magnetic). This is currently becoming known as EHS. (Electromagnetic hypersensitivity is a claimed sensitivity to electromagnetic fields, to which adverse symptoms are attributed.) She experiences a deep burning sensation throughout her entire body, leaving her in pain and exhausted after a pulse has occurred...
