Unlocking Binding Energy Solutions for Part C)ii - Tips and Strategies
The discussion focuses on solving part c)ii of a binding energy problem, where the user initially miscalculated the energy in mega joules instead of kilojoules. After recalculating, they found a binding energy closer to the expected value but still needed to convert from kJ/kg to kJ/mol. The conversation shifts to part d)ii, where the user seeks clarification on calculating the volume per atom for mercury, mistakenly referencing neon. Participants emphasize the importance of unit tracking throughout calculations to avoid errors. The discussion highlights the need for precise unit conversions and careful calculations in physics problems.
Bolter
Working out how to calculate binding energy
l = 1/2Nne
Here is the question:
Stuck on how to complete part c)ii
Here is what I have done so far as well as trying to answer part c)ii
Any help would be appreciated! Thanks
37 kJ = 37x103 J.
Likes berkeman
kuruman said:
37 kJ = 37x103 J.
Oh shoot yes you’re right. I don’t know why I processed it at as mega joules
So doing the following calculation again gives
Binding energy = (2 * 293000) / (6x10^23 * 7) = 1.41x10^-19 J which is closer to the answer but still not right
296 kJ/kg. You need kJ/mol.
So to convert from kJ/kg to kJ/mol, I must multiply kJ/kg by the molar mass?
I did this and got the following
Binding energy = 2(293000 * 0.20)/(6x10^23)(7) = 2.79... x10^-20 J which is roughly equal to 2.8x10^-20 J
I also got another part that I need help with if you don’t mind
Not entirely sure how to approach part d)ii but I suppose I had done part d) i right
di is right. Not sure what the problem is for dii - find the volume per atom, as you did for Hg.
To find volume per atom. I know that 1.0691... x10^-4 moles of Hg is contained in 2x10^-4 m^3.
So to firstly get the volume per mole of Hg, I do ' 2x10^-4 / 1.0691...x10^-4 ' which gives 1.870... volume per mole
Dividing 1.870... by avogrado's constant is '1.870... / 6.022x10^23 = 3.106... x 10^-24 volume per atom
Cube rooting volume per atom number should give the spacing which comes out to be '1.459... x10^-8 m'
Would you agree that these steps are the right way of doing this?
Yes, except that you're talking about neon, not mercury.
Likes Bolter
Yes, sorry I got mixed up with the wording somehow
The other thing is that I would be more explicit about tracking units through the calculation. So rather than say "1.870 volume per mole" I would say "1.870 m3 volume per mole"; likewise "3.106 x 10-24 m3 volume per atom". In this case, as you're dealing in m all the time, it's not so critical, but if you're switching between e.g. m and cm, or J and kJ, you can easily make mistakes if you don't keep track of units.
Likes Bolter
