How can the constant and x^12 terms be found in the expansion of (3/x - x^3)^8?
  • Thread starter angel_eyez
In summary, the Binomial Theorem is a mathematical formula used to simplify and solve problems involving binomial expressions. Its general formula is (a + b)^n = Σ_(k=0)^n (n choose k) a^(n-k) b^k, where n is the exponent, a and b are the binomial terms, and k is the index of summation. It can be applied to real-world problems in fields such as statistics, probability, and physics. However, it has limitations such as only being applicable to binomial expressions with a positive integer exponent and may not always provide an exact solution in certain cases.
angel_eyez
i don't get this question
in the expansion of (3/x - x^3)^8 find
a) the constant term ( is dere an easier way to find this instead of expandin the equation n den finding it)
b) the term containin x^12
The expansion of [itex](x + a)^n[/itex] gives terms:
[tex](x + a)^n = \sum_{k=0}^n \left(\begin{array}{c} n\\k\end{array}\right) x^ka^{n-k}[/tex]
where the coefficient:
[tex]\left(\begin{array}{c} n\\k\end{array}\right) = \frac{n!}{(n-k)!k!}[/tex]
So multiply your expression by -1/x^8 and then do the binomial expansion. Then multiply the binomial terms by -1/x^8 to find the constant term and one containing x^12 (if there is one).
[tex](3/x - x^3)^8 = (\frac{-1}{x}(x^4-3))^8 = \frac{1}{x^8}\sum_{k=0}^n \left(\begin{array}{c} 8\\k\end{array}\right) x^{4k}(-3)^{8-k}[/tex]
Can you do the rest from that?
AM
i still kind adont get it..can u please complete it:blushing:
It's just doing the arithmetic now.
The "kth" term is
[tex](-3)^{8- k}\left(\begin{array}{c} 8\\k\end{array}\right)x^{-8}x^{4k}= (-3)^{8- k}\left(\begin{array}{c} 8\\k\end{array}\right)x^{4k-8}[/tex]
a) The constant term has no x term or an x0 term. For what value of k is 4k- 8= 0? What is
[tex](-3)^{8- k}\left(\begin{array}{c} 8\\k\end{array}\right)[/tex]
for that k?
b) For what value of k is 4k- 8= 12? What is
for that k?
1. What is the Binomial Theorem?
The Binomial Theorem is a mathematical formula that allows us to expand a binomial expression raised to a positive integer power.
2. How is the Binomial Theorem used?
The Binomial Theorem is used to simplify and solve problems involving binomial expressions, such as finding coefficients, expanding expressions, and solving equations.
3. What is the formula for the Binomial Theorem?
The general formula for the Binomial Theorem is (a + b)^n = Σ_(k=0)^n (n choose k) a^(n-k) b^k, where n is the exponent, a and b are the binomial terms, and k is the index of summation.
4. How can the Binomial Theorem be applied to real-world problems?
The Binomial Theorem can be applied to real-world problems in fields such as statistics, probability, and physics. For example, it can be used to calculate the probability of a certain outcome in a series of events, or to model the trajectory of a projectile.
5. Are there any limitations to the Binomial Theorem?
While the Binomial Theorem is a powerful tool, it does have some limitations. It can only be applied to binomial expressions, and the exponent must be a positive integer. Additionally, it may not always provide an exact solution in some cases where the terms are not easily simplified or when dealing with complex numbers.
