How Do Falcon Attacks Alter the Flight Path of Their Prey?
  • Thread starter Thread starter mnafetsc
    Bird Collision
Peregrine falcons alter the flight path of their prey, such as ravens, by striking them at high speeds to protect their nests. In a specific incident, a falcon weighing 620 g and flying at 20.0 m/s collided with a 1.40 kg raven flying at 9.0 m/s, resulting in the falcon bouncing back at 5.0 m/s. The discussion involves calculating the angle of change in the raven's direction and its speed post-collision using conservation of momentum. Attempts to solve the problem included breaking down the momentum into components, but initial calculations yielded incorrect angles. The complexity arises from the inelastic nature of the collision, leading to confusion in the calculations.
mnafetsc
To protect their young in the nest, peregrine falcons will fly into birds of prey (such as ravens) at high speed. In one such episode, a 620 g falcon flying at 20.0 m/s hit a 1.40 kg raven flying at 9.0 m/s. The falcon hit the raven at right angles to its original path and bounced back at 5.0 m/s. (These figures were estimated by the author as he watched this attack occur in northern New Mexico.)
A.By what angle did the falcon change the raven's direction of motion?
B.What was the raven's speed right after the collision?
P=mv
I put the falcon on the y-axis and the raven on the x axis, I ten tried to find the a and y components of p then did theta= arctan9p2/p1) which gave me 45 degrees-wrong
I then tried to find the x and y components using
m_F_v_Fi + m_R_V_Ri = m_F_v_Ff + m_R_V_Rf
Solving for v_Rf for the x and y compents I got 9 and 8.16 respectively, the had theta= arctan(8.16/9)= 42 degrees again wrong.
P=mv
Precisely how did you get that? Are you assuming a perfectly elastic collision? That's probably not correct. What percentage inelasticity are you assuming?
Pretty much I did p=sqrt(p_1_^2 +p_2_^2
But I realize that is wrong because its not elastic situation, I know is inelastic, but not perfectly inelastic so I used the second equation thinking that would work, I'm not quite sure were to go from there.
Never mind I was doing it correctly, I just kept making some unknown calculation error that kept giving me the wrong angle.
