gfd43tg
- 48
The circuit below is a BJT common collector amplifier. Find both the voltage gain (AV = Vout / Vin) and the current gain (AI = Iout/Iin). As with Problem 1, this may seem hard to parse at first, but it is actually pretty straightforward. Carefully replace the BJT symbol with the model for a BJT we used in class, making sure the base (B), emitter (E), and collector (C) terminals are connected properly, then use any method you want to solve for Vout!
For this problem, you can assume Vin ≫VBE.
I'm not sure if my connections are right. Also, with a BJT, if current and voltage are amplified (according to my solution), what is being reduced? I don't think you can get these gains with no losses incurred.
