Black Hole Mass Flows: Is the Balance 0%?
The discussion centers on the mass flow dynamics of black holes, questioning whether the total mass falling into a black hole can balance out to zero when accounting for various forms of mass-energy loss. Participants note that the mass-energy equivalents radiated from the accretion disk, Hawking radiation, and relativistic jets could theoretically sum to the total mass falling into the black hole. However, this scenario is deemed plausible primarily for small black holes, as larger ones would not evaporate quickly enough. It is emphasized that the energy radiated does not originate from within the black hole itself. Ultimately, the conversation concludes that a black hole would cease to exist once it lacks sufficient mass to sustain itself, although Hawking radiation is a slow process.
Islam Hassan
Is the following breakdown possible with respect to the matter falling into a black hole:
+ Total Mass falling into BH per unit time 100%
- Mass-energy equivalent radiated from accretion disk -X%
- Mass-energy equivalent radiated as Hawking radiation -Y%
- Mass-energy equivalent ejected in relativistic jet -Z%
= Nil final mass-energy balance = 0%
Astronomy news on Phys.org
Yeah, sure.
It would have to be a small BH though.
And keep in mind that the energy radiated from the disk and jets is not energy from inside the BH.
zhermes said:
Yeah, sure.
In that case a BH should die off as soon as there is no more sufficient mass to feed/sustain it, no?
IH
Eventually, yes. But the emission of hawking radiation only radiates energy very slowly. Only very small BHs can evaporate this way.
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
