Can Black Holes Alter the Movement of the Universe Through Light Bending?
In summary: Time passing at c in a Schwarzschild black hole refers to the fact that observers outside the black hole will see time move slower than observers inside the hole.
taeth
34
When a star turns into a black hole does it change the movement of the Universe at all? Through a funneling effect?
Astronomy news on Phys.org
Hi taeth. Welcome to PF. Not sure what you mean by movement of the universe. Things move within the universe relative to each other. The universe as a whole does not move. There is nothing for it to move through, so the short answer is no. Black hole formation has no effect on anything aside from spacetime curvature [increased gravity] in the volume of space previously occupied by the precursor object [star].
K thanks sorry I didn't explain myself very good, but a black hole has more mass than the star who's place it takes... Also do black hole ever die out because they emmit radiation I was just curious if they could run out?
Not initially. The star collapses to the black hole and its mass is conserved. Later inflow may increase the mass.
Yes they can. It's called evaporation, and it's a real prediction. Every time a particle escapes the BH because of the Hawking mechanism, the BH loses that particle's mass. But evaporation may take a very, very long time.
Might the universe as a whole be rotating? Would it matter if it were?
Hmm...all motion is relative. So the question is...rotating relative to what? You're talking about the universe here...the whole of existence. There is nothing else to compare it with.
Goedel (yes the famous "incompleteness" Goedel) developed the equations for a rotating version of general relativity. He showed that such a universe contains closed timelike paths, i.e. time travel is possible.
Most physicists have considered Goedel's universe to be unphysical, for exactly the reaon cepheid gave; rotating with respect to what?
rotating with respect to another universe separated by a membrane like bubbles inside of bubbles...
...with black holes maintaining the equilibrium of any particular universe around a fixed expansion point in multiversal time :smile:
Does time go slower in a black hole?
I didn't think that rotational motion needs a reference.
For example, if I put a fly in a jar, attach string to the jar and swing it around in circles, the fly feels an artificial gravity caused by me doing so. A spider, outside the jar watches me do this, but he does not feel the artificial gravity. If all of a sudden, I considered the fly in the jar to be the origin of my coordinate system (ie it is now still), then the spider on the wall outside the jar should begin to feel an artifical gravity caused by the room spinning around the jar. But obviously he will not.
I think its because your direction keeps changing in circular motion. Therefore, circular motion needs no reference point, which opens the door for the universe to rotate.
Or another example, in most physics problems such as dropping a rock, you consider the surface of the Earth to be stationary and not rotating. But in reality, if I were to swing a pendulum, over a few minutes I could note a change in direction, proving that the Earth rotates, but relative to nothing except its own instantainous momentum.
Yes, I pretty sure it does. I think one of my friends told me that time is almost slowed down to 0.
Interesting property of a Schwartzschild black hole; once you cross the event horizon, time and the radial space direction swap, so that as it were, things inside the horizon "age" toward the singularity at the center, i.e they can't escape going there. This time is not slow, my impression is that it passes at c.
Where time slows down, is close to the horizon, on the outside, and then ONLY for far-away observers. To them, looking through a telescope at something falling into the hole, it seems literally to take forever to do so, although observers falling with the object see time as passing normally. This is due to the warping of spacetime by the huge gravity of the hole.
selfAdjoint said:
... This time is not slow, my impression is that it passes at c...
If you have time, could you elaborate on that? I am not able to understand what is meant by time passing at c.
I know little about black holes, but from what I have read, I understand it that they can bend light. So assuming you were an ethereal being and were standing near the center of a black hole, if you streched out your arm tangent to the center (I imagine black holes as sphereical) and looked at it, would it appear bent (also assuming some light makes it to your eyes from you arm)?
Related to Can Black Holes Alter the Movement of the Universe Through Light Bending?
What is a black hole?
A black hole is a region in space where the gravitational force is so strong that nothing, including light, can escape from it. It is created when a massive star collapses in on itself at the end of its life.
How do black holes affect reality?
Black holes have a significant impact on the fabric of the universe. Their immense gravitational pull can distort space and time, and their presence can influence the movement of other objects and even entire galaxies.
Do black holes destroy everything that enters them?
While it is commonly believed that black holes devour everything that enters them, this is not entirely true. Anything that crosses the event horizon, the point of no return, will be pulled into the black hole. However, some matter can escape through powerful jets of radiation emitted by the black hole.
Can black holes be seen?
Black holes themselves cannot be seen because they do not emit any light. However, their presence can be detected by observing the effects they have on their surroundings, such as the bending of light or the movement of nearby stars.
Could a black hole destroy the entire universe?
While black holes are incredibly powerful, they do not pose a threat to the entire universe. The largest black holes, known as supermassive black holes, are found at the centers of galaxies and play a crucial role in their formation and evolution.
  • Astronomy and Astrophysics
