I Black Holes: Time Bidirectional?
mousheng xu
I just watched a youtube video saying that somewhere in a black hole, time is bidirectional (can go to the future and can go to the passed), but space is one-directional.
Any introduction material on this subject?
Thanks in advance!
YouTube is not a good source for learning science.
This is not correct. Which is a good illustration of why YouTube is not a good source for learning science.
There are plenty of good textbooks on General Relativity out there. Sean Carroll's lecture notes on GR are online and covers the basics of black holes:
https://arxiv.org/abs/gr-qc/9712019
Likes Dale
Moderator's note: Thread moved to relativity forum.
If you write down the metric (the mathematical object describing the "shape" of spacetime) outside a black hole using Schwarzschild coordinates, and repeat the exercise inside, you find that they look the same. It's natural enough to use the same coordinate label inside and outside since the maths looks the same. But it turns out if you do that then outside you are using the letter ##t## to describe your position in time and the letter ##r## to describe your position in space, but inside the hole you are using ##t## to describe your position in space and ##r## to describe your position in time.
The important thing to realize is: just because I label something ##t## does not mean it's actually time. The universe does not care what letters I use. Your YouTuber has not realized this (or has chosen to ignore it for coolness factor).
So yes, inside the black hole I can freely increase or decrease my ##t## coordinate, but my ##r## coordinate always increases. But this is because I'm using ##t## to describe my place in space and ##r## to describe my place in time, not because I'm free to travel backwards in time.
An analogy to this can be made on the surface of the Earth. Face north. Now north is forwards, south is backwards, east is right and west is left. Take a step forward. Same thing - north is forwards, etc. Keep stepping forwards. Eventually you reach the north pole, where every direction is south. One more step and the pole is behind you - so suddenly north is backwards, south is forwards, east is left and west is right. You can now take to YouTube and make videos about how it's impossible to move forward at the north pole (because north is forward and every direction is south) and that forward and backward change meaning when you go through the north pole! Or you can just realize that north doesn't always mean forwards.
Likes lomidrevo and PAllen
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
According to the General Theory of Relativity, time does not pass on a black hole, which means that processes they don't work either. As the object becomes heavier, the speed of matter falling on it for an observer on Earth will first increase, and then slow down, due to the effect of time dilation. And then it will stop altogether. As a result, we will not get a black hole, since the critical mass will not be reached. Although the object will continue to attract matter, it will not be a...
