How Does Friction Affect Spring Motion on a Rough Surface?
The discussion focuses on calculating the coefficient of kinetic friction between a block and a rough surface when attached to a spring. The spring, with a constant of 70 N/m, initially stretches 63 cm before releasing the block, which then stops after being dragged. Participants emphasize the importance of understanding the force exerted by friction, which opposes motion, and the conservation of energy in the system. The potential energy of the spring decreases as it does work against friction, leading to a loss of energy that must be accounted for. The conversation highlights the need to connect potential energy changes with the work done against friction to solve the problem effectively.
jspek9
A relaxed spring with spring constant k = 70 N/m is stretched a distance di = 63 cm and held there. A block of mass M = 7 kg is attached to the spring. The spring is then released from rest and contracts, dragging the block across a rough horizontal floor until it stops without passing through the relaxed position, at which point the spring is stretched by an amount df = di/9.
What is the coefficient of kinetic friction µk between the block and the floor?
The formula I'm trying to use is Ff = μFn
What I can't understand is Ff. Its defined as "the force exerted by friction". But what does that mean and how can I solve for it? The problem wants me to use the Work Energy Theorem but I can't piece it all together in my head and I just can't seem to understand constants as a whole anyways so I could really use some insight here.
Thanks as always:wink:
firstly, the "force exerted by friction" always acts opposite to the direction of motion.
To solve the problem think about how much potential energy the spring had initially and how much it has finally. Where has the extra energy gone? (remember energy is conserved)
-Spoon
OK I've been looking at my potential energy formulas and I don't see the connection.
I can't figure out what in the world I'm missing.
On a side note just curious but is Spoon for Spoon Sports?:smile:
Ok, the change in energy of the system should be negative, meaning you should have less potential energy than when you started. Where did the energy go, because it must be conserved?
Well the system had to overcome the frictional force to move, I.e the system did work.
Remember that work = force * distance (applied).
And no, I've never heard of spoon sports, just a nickname I acquired a few years ago :)
Hope that helps without giving it all away
-spoon
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
