Electronics Can I Convert My Guitar Amplifier into a Bluetooth Device?
To convert a guitar amplifier into a Bluetooth device, it's essential to connect the output from a Bluetooth speaker to the amplifier's Auxiliary (Aux) port. However, the Aux input typically expects a weak signal, while the Bluetooth speaker output is amplified, which could potentially damage the amplifier if connected directly. To avoid this, it's recommended to use a level control circuit, such as a variable resistor (potentiometer), between the Bluetooth output and the Aux input. This setup allows for adjusting the signal level to prevent overdriving the Aux input, ensuring safe and effective operation.
TechTree
Hello, I have a guitar amplifier I'd like to convert into a bluetooth device. Using it's current power supply and allow it to receive a bluetooth input. I have a bluetooth speaker that I took the electrics from. The bluetooth speaker is digital, but when it outputs to the speaker it's an analogue signal. How could I connect the bluetooth speaker to the guitar amplifier? The guitar amplifier has an Auxiliary Port, could I just connect the output going to the speaker of the bluetooth deivce directly to the Auxiliary Port? Or would that not work.
Here are some photos of the guitar amplifier & bluetooth speaker:
Thanks :wink:
You need to look at the input specs of the Aux port. Some of types of input ports are designed to take a weak signal like microphone or guitar pickup. While the output to the speaker of the Bluetooth device has already been amplified
Thanks for the reply! That makes sense, I'm pretty sure the input of the Aux port is designed to take weak signals as you mentioned. Would there be some way I could connect the bluetooth speaker output to the Aux input without it passing through the amplifier? What would happen if I passed the amplified signal directly into the Aux input, would it damage something or just wouldn't work?
Many thanks!
This is speculation. I'm guessing that any decently designed amp should take into account that somebody migjt accidentally plug the wrong wire into that jack. So there should be some protection to keep from blowing expensive parts.
Hopefully the worst thing that would happen is you get a distorted signal.
How you proceed depends on your risk tolerance. Try to do some research on the manufacturer's website, as to what type of signal it can handle,and what happens if that is exceeded.
Likes TechTree
not usually
you would over-drive the AUX input
the easiest way is to put a level control in circuit between the BT audio out and the AUX input. That way you can set the levelso that the input isn't overloaded
here's a quick schematic I drew up
and an example of a 20k variable resistor (Pot)
Cheers
Dave
Likes scottdave, jim hardy and TechTree
Thanks Dave, worked perfectly :)
Likes davenn
Philips Hue was the very first provider of smart LED bulbs that can be controlled wirelessly. Over the years, as Philips sold ever improved models of smartbulbs, it became very difficult to identify exactly which model one of their bulbs is. Once I've installed a smart bulb, there is some additional information in the Hue app about the bulb model, but even then, I found that it requires information from both the app and from what's printed on the outside of bulb to be sure what the actual...
Some time ago I posted this Raspberry PI DIY Mass Spec using Raman Scattering. It's was something of a cumbersome project though, needing a 3D printer and special heat-resistant plastic giving of carcinogenic fumes during printing. To be blunt it was also not very mobile and interpreting the results was further cumbersome Recently though, I've been told that Arduino, and it's various sensor packages, has matured to the point where it's a usable alternative. Now I realize that a cigarette...
