Bode phase plots and initial angles of transfer functions
Understanding the initial phase angle of a transfer function can be simplified by analyzing its components. For the transfer function L(s) = 4/(s(0.4s+1)(s+2)), the initial angle is determined by the contributions from the numerator and denominator. A negative term in the numerator adds 180 degrees to the phase, while the degree of the denominator affects the phase subtraction. When evaluating the angle as s approaches jω, the behavior of each factor in the denominator must be considered. Mastering these concepts can clarify how to determine the initial phase for various transfer functions.
vysero
Hello everyone. So I have a test coming up and I am struggling with the concept of figure out what the initial phase or angle of a transfer function is. For instance, consider the following transfer function:
L(s) = 4/s(.4s+1)(s+2)
So the initial angle for L(s) is -90 degrees. Is there a simple trick for figuring that out given any transfer function? I have heard that if there is a negative in the numerator then you add 180 degrees of phase or depending on the degree of the denominator you would subtract phase.
Can someone help me sort this out?
I assume you mean this function:
L(s) = 4/(s(.4s+1)(s+2))
Some thoughts to help you get to the answer:
Say you have two complex numbers z1 and z2, what is arg(z1 z2) and arg(z1/z2) in terms of arg(z1) and arg(z2)?
What happens to the angle of each factor in the denominator as s = jω, ω → 0?
What mathematics software should engineering students use? Is it correct that much of the engineering industry relies on MATLAB, making it the tool many graduates will encounter in professional settings? How does SageMath compare? It is a free package that supports both numerical and symbolic computation and can be installed on various platforms. Could it become more widely used because it is freely available? I am an academic who has taught engineering mathematics, and taught the...
  • · Replies 40 ·
