Bond Angles for Different Molecules - Can Someone Help Me Understand Them?
  • Thread starter Thread starter hotsexyveronica
    Angles Bonding
The discussion focuses on bond angles for various molecules, with many participants suggesting that angles like 109.5 degrees are common for tetrahedral structures, while 180 degrees is typical for linear molecules. Specific examples include CF4, NH3, SO4^2-, and NH4+ all having bond angles of 109.5 degrees, while H2S and HCl exhibit 180-degree angles. Participants emphasize the importance of understanding molecular structure and electron configuration to accurately determine bond angles. There is a call for clarification on the original question and a request for the methodology used to derive the angles. Overall, the conversation highlights the need for a solid grasp of molecular geometry to understand bond angles correctly.
hotsexyveronica
CF4 is it 109.5 degrees for the angle
NH3 109.5 degrees for this angle
SO4^2- 109.5 for this angle
NH4+ 109.5 degrees for this angle
H2S 180 degrees for this angle
PO4^3- 109.5 degrees for this angle
HCl 180 degrees for this angle
NF3 190.5
SiH4 190.5
BF3 190.5
C2H6 190.5
C2H4 190.5
CH2O 190.5
I don't think I am doing these right can someone show me please
Well do you understand the molecular structure or the electron configuration b/c that will help you understand the angles. Also the angle represents the the lowest electron repulsion. You could basically look this up in your textbook...
NF3 190.5
SiH4 190.5
BF3 190.5
C2H6 190.5
C2H4 190.5
CH2O 190.5
Please write down the original question EXACTLY as it was given to you. We have no idea what angles you are referring to. Also, show us how you arrive at some of those angles, so we can help/correct you.
Also, HCl has only 2 atoms - there are no bond angles to speak of.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
