Chemistry Understanding Bonding Energy in Water for Electrolysis Calculations
The discussion focuses on the calculations related to bonding energy in water for electrolysis. The user compares their results for the distance between atoms and bond energies with those from a referenced document, noting discrepancies in values for r12 and U12. They highlight that the covalent bond energy of H-O is critical for accurate electrolysis calculations, with various sources providing slightly different values. The conversation emphasizes the inadequacy of the model used, suggesting that the bond between oxygen and hydrogen is more covalent than ionic, which complicates the calculation of binding energy. The user seeks more accurate references for covalent bond energy and formulas for calculating bond energies, indicating a need for a deeper understanding of quantum mechanics.
tommyhp2
Find the required energy and volt needed for electrolysis of water
Coulomb's law: F = k * q_1 * q_2 / r*r
V = W / q
Hello everyone,
I'm just doing a bit of review of math to be used in electrolysis calculations. From the reference:
https://www.ccmr.cornell.edu/wp-con...o_Skyler_splitting-water-with-electricity.pdf
the result for r12 on page 4, the author has 1.5 * 10e-11 m. Google sheets and MS Excel has 1.89e-10 = sin(52) * 2 * 9.6e-11.
Also, for U12 using my result of r12 instead of the author's, I got 1.28e-19 instead of the author's 1.6e-19. If I used the author's result for r12, I got 1.62e-18.
And the covalent bond energy of H-O = 464 kJ / mol to break the bond from:
https://opentextbc.ca/chemistry/chapter/7-5-strengths-of-ionic-and-covalent-bonds/
The total U from 'splitting water with electricity' is too low 8.54e-19 J (author's) or 8.86e-19 J (based upon my results of r12) from the covalent bond energy above (464 + 464) * 1000 / 6.022e-23 = 1.54e-18 J.
Would someone please check if my findings are correct? Does anyone know where I can get a more accurate than the above for covalent bond energy reference?
Thanks,
Tommy
[Edit] PS: If I use the complete calculation for covalent bond energies for the electrolysis reaction:
2 H-O-H => 2 H-H + O-O
( 2(464 * 2) - (2 * 436) - 140 ) * 1000 / 6.022e23 = 1.4e-18 J
But to get the net energy required for 1 molecule of water, 1.4-18 J / 2 = 7e-19 J.
Which still doesn't equate to electrostatic force result.
The angle is given in degrees. The sin function in the spreadsheet expects radians. That said, the result given is off by a factor of 10. (You can easily see this by considering that, with the numbers as written, the two hydrogen would be about 6 times closer to each other than to the oxygen atom, which wouldn't result in an angle of 104°.)
The value of U12 in the document is correct.
The model used is completely inadequate. The bond between oxygen and hydrogen is more covalent than ionic, and there is no way that calculating the Coulomb interaction between the partial charges on the atoms will give the right binding energy for water.
https://courses.lumenlearning.com/introchem/chapter/bond-energy/
For instance, the HO-H bond in a water molecule requires 493 kJ/mol to break and generate the hydroxide ion (OH–). Breaking the O-H bond in the hydroxide ion requires an additional 424 kJ/mol. Therefore, the bond energy of the covalent O-H bonds in water is reported to be the average of the two values, or 458.9 kJ/mol. These energy values (493 and 424 kJ/mol) required to break successive O-H bonds in the water molecule are called ‘bond dissociation energies,’ and they are different from the bond energy. The bond energy is the average of the bond dissociation energies in a molecule.
If you have access to the CRC Handbook of Chemistry and Physics, it is always a good reference for these kind of numbers.
DrClaude said:
The angle is given in degrees. The sin function in the spreadsheet expects radians. That said, the result given is off by a factor of 10. (You can easily see this by considering that, with the numbers as written, the two hydrogen would be about 6 times closer to each other than to the oxygen atom, which wouldn't result in an angle of 104°.)The value of U12 in the document is correct.
Thank you for the correction. I saw the 'angle' in the popup tip but didn't read down far enough for the fine print of expecting radians. Correcting that does have the right U12.
I understand about the movements in 3-D space and dissociation energy. I've figured a better approximation is to use integral but I'm after peak energy required to break its strongest bond. I was hoping the model I've found would provide that since the O-H bond varies 0.957 A to 1 A and the H-O-H angles varies from 104.52 to 109.5 from my research.
Thanks for the tip on CRC Handbook. I'll see if I can get a copy. By any chance do you know where I can get reference to the formulas to calculate either covalent or ionic bonds? I don't want to reinvent the wheel by reviewing calculus to derive the formula(s) based upon the graph.
hmm... After some more research, it seems I need to pick up quantum mechanics due to chosen CS major in college.
tommyhp2 said:
´By any chance do you know where I can get reference to the formulas to calculate either covalent or ionic bonds? I don't want to reinvent the wheel by reviewing calculus to derive the formula(s) based upon the graph.
This is a quantum chemistry problem. You need some specialized quantum mechanics, and even then the problem can only be solved numerically.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
