Bouncing Ball Dissipative Interaction
A basketball weighing 0.62 kg dropped from 1.6 m rises to 64% of its height after the first bounce, dissipating 3.5 J of energy. The initial potential energy is calculated to be approximately 9.72 J. After the fourth bounce, the potential energy is about 1.63 J. The energy dissipated specifically during the fourth bounce is found to be around 0.92 J. The calculations confirm the energy loss across the bounces, illustrating the concept of dissipative interaction in bouncing balls.
B3NR4Y
A 0.62-kg basketball dropped on a hardwood floor rises back up to 64% of its original height. If the basketball is dropped from a height of 1.6m , how much energy is dissipated in the first bounce? How much energy is dissipated in the fourth bounce?
U(x) = mgh
I answered the first part correctly, and found that the change in Energy, or dissipated energy, after the first bounce is 3.5 J. I am having trouble answering the second part however, I was able to convince myself that U(x) = 0.62-kg*9.8*(1.6*0.64^n) where n=the number of bounces by thinking about it for a while. So I found the initial potential energy to be 9.7216 J and when I calculated the final potential energy after four bounces I got ~1.63 J. Subtracting final from initial, I got an answer of ~8.1 J as the change in energy, but that is wrong. I don't know how, can anyone steer me in the right direction (preferably in the next 20 minutes (I promise I didn't procrastinate :oops:))
You got the right change in energy, but that was for the total change from initial to after the 4th bounce.
What about the change in the 4th bounce (difference of 3rd to 4th)?
Hm, so the energy after the 3rd bounce is U(x) = ~2.54 and then after the forth bounce it would be ~1.63 so I subtract the two and get ~0.92 J
Looks right.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
