Wave Transmitted Amplitude Greater than Incident: Conditions?
  • Thread starter gyht42
  • Tags
    Waves
In summary, the conversation discusses the possibility of the amplitude of a transmitted wave being greater than the amplitude of an incident wave when traveling from a dense to a less dense medium. The total power is split between the reflected and transmitted waves, resulting in different amplitudes. The speed of the transmitted wave is also affected by the density of the medium. Further analysis using the wave equation and boundary conditions may provide more insights.
gyht42
My question concerns a wave traveling from a dense into a less dense medium. Is it possible that the amplitude of the transmitted wave be greater than the amplitude of the incident wave? What conditions would apply?
Have you tried to analyze it using the wave equation and boundary conditions?
You may find this http://www.kettering.edu/physics/drussell/Demos/reflect/reflect.html" . At the boundary, the incident want splits into a reflected wave and a transmitted wave. The total power that was contained in the initial wave is now split among the reflected and transmitted wave, so the amplitudes must necessarily be different. Waves on a string travel at a speed inversely proportional to the string mass, so if the transmitted wave is on a less dense string, it will be going faster. If you are more interested in pressure waves through bulk matter, than it gets more complicated because there are different types of waves possible and the phase of the matter matters.
1. What is meant by "wave transmitted amplitude greater than incident?"
When we talk about wave amplitude, we are referring to the maximum displacement of a wave from its equilibrium position. In the case of a wave that is transmitted from one medium to another, the transmitted amplitude refers to the maximum displacement of the wave in the second medium. If this amplitude is greater than the incident amplitude (i.e. the maximum displacement of the wave in the first medium), we say that the wave has experienced amplification.
2. What are the conditions for a wave to experience amplification?
There are a few different conditions that can lead to a wave experiencing amplification. One of the most common is when the second medium has a higher refractive index than the first medium. This means that the speed of the wave will be lower in the second medium, causing the wavelength to decrease and the amplitude to increase. Another condition is when the incident wave is very low in energy and the second medium has a higher energy density, causing the wave to gain energy and amplitude as it passes through.
3. How does wave polarization affect the transmitted amplitude?
Wave polarization refers to the orientation of the oscillations of a wave. When a wave is transmitted from one medium to another, its polarization can change, which can affect the transmitted amplitude. For example, if a vertically polarized wave is incident on a medium with a horizontal polarization, the transmitted amplitude will be close to zero. However, if the incident wave is at a 45-degree angle to the polarization of the medium, the transmitted amplitude can be amplified.
4. Can a wave experience amplification in a vacuum?
No, a wave cannot experience amplification in a vacuum. Amplification requires the wave to pass through different mediums, where its speed and energy can be altered. In a vacuum, there are no other mediums for the wave to pass through, so it will maintain its original amplitude.
5. How is the amplitude of a wave related to its energy?
The amplitude of a wave is directly proportional to its energy. This means that as the amplitude increases, so does the energy of the wave. This relationship can be seen in the formula E=hc/λ, where E represents energy, h is Planck's constant, c is the speed of light, and λ is the wavelength. The higher the amplitude (represented by λ), the higher the energy of the wave.
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Electromagnetism
