What Are the Steps to Solve a Boundary Condition Problem with Three Conditions?
Mazimillion
Hi, this question has been bugging me for weeks and any help would be greatly appreciated.
In lectures we derived a general expression for the potential distribution across the xy half plane (y>0) in terms of a known potential distribution along the boundary defined by the x-axis where the potential,phi, is described by Laplace's equation in 2-D. In the case where the potential along the boundary is: 0 for x greater than equal to a, 0 for x less then equal to -a, phi0 for -a<x<a, deduce an expression for the potential distribution throughout the half plane.
I think what is getting me are the 3 boundary conditions - I'm not sure exactly what i should be doing with them to find values for the coefficients.
i'm sorry that it's not very clear but if you have any ideas they would be greatly appreciated
thanks
The solution to these things is always Fourier analysis, or something like it.
There are two boundary conditions here: the potential should go to zero as y gets large, and it should become your specified function of x when y is 0. Because we want the potential to die off, we have a decaying exponential in the y direction, and the general solution is a weighted sum of terms like like Ae^(-ky)e^(ikx). Since you can't restrict the value of k at all, this sum becomes an integral: Int A(k) e^(-ky)e^(ikx) dk. When y is 0, you know that the potential is your given f(x), so f(x) = Int A(k) e^(ikx) dx. So A(k) is just the Fourier transform of your boundary condition f(x)!
So, find A(k) by taking the Fourier transform of f(x), plug it into your original integral with e^(-ky), and you are done!
Thanks for that - I've really made some progress. The only problem now is applying the boundary conditions on the x-axis. How do I apply both phi=0 for x<-a, x>a and phi=phi0 for -a<x<a?
I'm probably missing something really simple but I've been pulling my hair out for ages.
Thanks
The integral I've mentioned is from k = negative infinity to positive infinity. f(x) is how I'm referring to your pulse between -a and a on the x axis.
The key is that A(k) and f(x) are a Fourier transform pair. Did they not discuss this in your class? So if f(x) = Int A(k) e^(ikx) dx, then A(k) = (1/2 pi) Int f(x) e^(-ikx) dx, where this integral is over all space. Since f(x) is zero except between -a and a, you can change the limits to there.
Got it now
Thanks a million, you've been a great help
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
