Bragg Law and Effect of Doubling Wavelength
Bragg's Law indicates that the angle theta changes when the wavelength is doubled, specifically represented by the equation dsinθ=mλ. The discussion revolves around predicting new maxima angles after doubling the wavelength, with initial maxima observed at 20.5 and 44.5 degrees. When calculating, doubling sin(20.5) yields a valid angle of 44.5 degrees, but doubling sin(44.5) results in a value greater than 1, which is not possible. This suggests that the 44.5-degree maximum does not have a corresponding maximum for the doubled wavelength, indicating a change in the pattern of maxima. The conclusion drawn is that there may only be one maximum at 44.5 degrees for the doubled wavelength scenario.
elemis
My lecturer discussed bragg's law a few weeks ago and described how the angle theta changes as the wavelength is doubled.
I can't seem to duplicate his result.
I know that the bragg condition for a maxima would reduce to : dsinθ=mλ when the wavelength is doubled.
In his example he knew that maxima were observed at 20.5 and 44.5 degrees but he gave no other values.
How would I go about predicting the angles at which the maximas are now observed ?
If you double λ and m and d stay constant, sinθ doubles as well. You can calculate sinθ in your example.
True, so sin(20.5) = 0.3502... This multiplied by 2 gives : 0.700... Sin inverse of this gives 44.5 degrees.
But if I double sin(44.5) I get a value larger than 1. How is it possible to take the sine inverse of this ?
EDIT : Does this imply there is only one maxima now at 44.5 degrees ?
The 44.5-maximum has no equivalent for the doubled wavelength, right.
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
