Brain teaser on inception pressure cookers
  • Thread starter Thread starter boenbrink
    Brain Pressure
Placing a smaller pressure cooker inside a larger one, both rated for the same temperature and pressure, raises questions about pressure dynamics. The inner cooker would not reach double the psi because the pressure inside both cookers is determined by the external conditions of the larger cooker. Instead, the inner cooker would equalize to the same pressure as the outer one, preventing any risk of explosion. The discussion highlights the importance of understanding pressure principles in closed systems. Overall, the scenario illustrates that pressure does not simply double in nested pressure cookers.
boenbrink
Ok, so my room mate and I were talking and came up with this question.
What would happen if you placed a smaller pressure cooker inside of a larger one?
Both are rated for the same temp and pressure.
Would the one inside reach double the psi?
Would it blow up?
Why would it? It's at the same temperature as the outer one and will therefore be at the same pressure.
So it should just double the pressure inside the smaller one?
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
