What is the Optimal Design for a DIY Briquetting Press Using Hydraulic Drive?
  • Thread starter Thread starter festivaals
    Drawing
A DIY briquetting press using a hydraulic drive can be designed with a hydraulic cylinder diameter of 60 mm and a circuit pressure of 200 bar, yielding a force of 56,000 N. However, the necessary force for pressing is approximately 200,000 N, indicating that adjustments may be needed for effective operation. A suggested resource for construction ideas is a link provided, although it may be more suited for industrial applications rather than small-scale setups. The discussion also highlights the importance of considering the size of the briquetting press, suggesting a backyard or garage scale. Overall, participants are seeking practical designs and specifications for a functional briquetting press.
festivaals
Hi!
I would like to make briquetting press of stalk material. I think it can be simple mechanism with hydraulic drive. If hydraulic cylinder diameter is 60 mm and circuit pressure of tractor 200 bar force from cylinder can be 56000 N. Necessary force in pressing cylinder is approximately 200000 N. Maybe someone have briquetting press drawing for construction ideas? What is the feeding hole size?
Hi
I think this link will be helpful for you making briquetting press drawing http://www.chipperanddryer.com/layout-plan-for-briquetting-plant-manufacturer.php
Thanks
Harinder
That's a nice link, Harinder, but I have a suspicion that it might not be appropriate. That appears to be a large industrial system, and such things don't usually "scale down" very well.
Festivaals, what size do you want this thing to be? From the dimensions that you mentioned, I was figuring a back-yard or garage sort of set-up.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
