Why Do Materials Like Polymers, Ceramics, and Metals Fracture Differently?
  • Thread starter vigintitres
  • Tags
    Fracture
In summary, the causes of fracture in polymers, ceramics, and metals vary depending on the material's properties. Polymers can be either brittle or softer due to factors such as their thermoset or thermoplastic nature, saturation, and chain length. Ceramics are intrinsically brittle due to their strong ionic bonds that make dislocations difficult to form and enable plasticity. For metals, inhibiting dislocation motion can increase brittleness, and sudden failure can occur when a sharp-tipped crack propagates through the material. The distinction between ductile and brittle materials is determined by the material's fracture toughness.
vigintitres
what actually causes polymers, ceramics and metals to fracture in either of these ways? From what I understand, polymers can be either brittle or softer which has to do with whether they are thermoset or thermoplastic, saturated or unsaturated, long chain or short chain, etc. but what makes ceramics intrinsically brittle in tension? Is it the ionic character? Is the only way that metals break due to the energy of dislocations becoming so great that it causes fracture? I know metals plastically deform because of dislocations but is it just inhibiting dislocation motion that increases the dislocation energy (G*b^2)?
When a sharp-tipped crack is loaded, there are two general possibilities: the area around the crack tip could plastically deform to increase the crack radius (blunting the crack and reducing the stress concentration), or the crack could continue to propagate through the material, causing sudden failure. This criterion distinguishes ductile and brittle materials. (Quantitatively, it corresponds to whether the fracture toughness is high (>100 MPa m1/2) or low (<1 MPa m1/2).)
For metals, inhibiting dislocation motion (thereby suppressing plasticity) will indeed make a material more brittle. I haven't studied ceramic mechanics closely, but I have seen brittleness in ceramics attributed to the strong ionic bond that precludes dislocations from being an easy method of enabling plasticity.
The fracture behavior of materials, whether they are polymers, ceramics, or metals, is largely determined by their atomic and molecular structure. In general, materials can fracture in two ways: brittle or ductile. Brittle fracture occurs when a material breaks without any significant plastic deformation, while ductile fracture involves significant plastic deformation before the material ultimately breaks.
For polymers, their fracture behavior is influenced by factors such as their molecular weight, molecular structure, and the presence of cross-linking. Thermoset polymers, which have a highly cross-linked molecular structure, tend to be more brittle than thermoplastic polymers, which have a linear or branched molecular structure. Saturated polymers, with no double bonds in their molecular structure, are also more brittle than unsaturated polymers, which have double bonds that allow for more flexibility. The length of the polymer chains can also affect its brittleness, with longer chains typically leading to more ductile behavior.
Ceramics, on the other hand, are intrinsically brittle due to their ionic or covalent bonding. These strong bonds make it difficult for the material to undergo plastic deformation, leading to brittle fracture. In addition, the presence of any defects or flaws in the ceramic structure can act as stress concentrators, making it more susceptible to brittle fracture.
For metals, the mechanism of fracture is more complex. While they are capable of plastic deformation, their fracture behavior is largely determined by the energy of dislocations in the material. Dislocations are defects in the crystal structure of a metal that allow it to deform plastically. When the energy of these dislocations becomes too great, they can cause the material to fracture. This can happen when the dislocations become tangled or pinned, inhibiting their motion and increasing their energy. The dislocation energy is also affected by factors such as the strength of the bonding between atoms in the metal, the size and shape of the grains in the metal, and the presence of impurities or defects.
In summary, the fracture behavior of materials is a complex and multifaceted topic that is influenced by various factors such as molecular structure, bonding, and defects. While polymers, ceramics, and metals all have different mechanisms for fracture, they all ultimately involve the breaking of atomic bonds within the material.
Related to Why Do Materials Like Polymers, Ceramics, and Metals Fracture Differently?
1. What is the difference between brittle and ductile fracture?
Brittle fracture occurs when a material breaks without significant plastic deformation, while ductile fracture involves plastic deformation before the material breaks. In other words, brittle materials break suddenly and without warning, while ductile materials can bend and deform before breaking.
2. What types of materials are more likely to exhibit brittle fracture?
Materials that are inherently strong and have low ductility, such as ceramics and some metals, are more likely to exhibit brittle fracture. This is because they have limited ability to deform and absorb energy before breaking.
3. How does temperature affect brittle vs. ductile fracture?
Low temperatures can make a material more brittle, as it reduces the material's ability to deform and absorb energy. This is why some materials, like glass, can shatter easily in cold temperatures. On the other hand, high temperatures can make a material more ductile, as it increases its ability to deform before breaking.
4. What are some real-life examples of brittle and ductile fracture?
Brittle fracture can be seen in glass, ice, and some types of rocks. Ductile fracture can be observed in metals like copper and aluminum, which can bend and deform before breaking. Another example of ductile fracture is the stretching and breaking of a rubber band.
5. How can we prevent brittle or ductile fracture in materials?
To prevent brittle fracture, materials can be designed with added ductility or toughness, or they can be used in environments with higher temperatures. Ductile fracture can be prevented by avoiding excessive stress and strain on a material, and by using materials with high strength and ductility.
  • Materials and Chemical Engineering
  • Science and Math Textbooks
17K
