Buffer Action and Titration: Does the Process Ever End?
When titrating H2A2+ with NaOH, a buffer system is established, leading to an equilibrium between H2A2+ and HA+ ions. As NaOH is added, the concentration of H2A2+ decreases, but due to the equilibrium, this change is minimal. The addition of NaOH increases the conjugate base concentration, influencing the acid concentration as well. While the total concentration of acid remains constant, the equilibrium concentrations of the various forms, including HA, do change. This discussion highlights the distinction between total and equilibrium concentrations in acid-base titration scenarios.
Titan97
If H2A2+ is being titrated with NaOH, a buffer forms.
The processes taking place are equilibrium between H2A2+ and HA+ ions, autoprotolysis of water and reaction of OH- ions with H2A2+ ions. As NaOH is added, the concentration of acid tends to decrease but because of the equilibrium
##H_2A^{2+} <=> HA^+ + H^+##, the decrease in concentration of acid is negligible.
Adding NaOH increases the amount of conjugate base which in turn increases the concentration of acid. Does this process never end? Whatever NaOH you add, the reacted Acid will form back.
Chemistry news on Phys.org
Be very, very careful about your wording.
There is a total concentration of all forms produced during the acid dissociation - so called "analytical concentration". We often speak about this kind of concentration even in solutions that don't - technically - contain an acid (like Na3PO4).
Then, there are equilibrium concentration of all forms, of those some (H3A, H2A+, HA2-) are acids (produce H+ during dissociation).
Finally, there is concentration of dissociated H+, which defines how acidic the solution is.
So, which of those you mean here:
(And no, as stated, this is not true, when you add NaOH to the solution concentrations of all acidic forms - H+, H3A, H2A+, HA2- - decrease).
The last sentence answers my query. I was actually solving a problem : https://www.physicsforums.com/threads/titration-of-amino-acid-with-strong-base.831012/
There, my teacher told me that the concentration of acid at any point remains the same. Maybe you have seen it.
If I take sodium acetate and titrate it slowly with NaOH, NaOH reacts with acetic acid formed by hydrolysis of sodium acetate. This decreases concentration of acid.
But according to Le Chatelier principle, as acid decreases, more acetate ions get hydrolysed to form acid. So the concentration of acid remains unchanged while concentration of salt will change.
Not exactly. Le Chatelier's principle tells you what general direction of the shift to expect, but not what the exact change will be. When you add base, acids get neutralized and pH goes always up. It is pretty easy to show that for each acid and conjugate base pair ratio of concentrations is
\frac {[HA]}{[A^-]} = 10^{pK_a-pH}
so if the pH changes concentration of the acid (HA in this case) doesn't stay constant.
But it is all the time not clear to me what you (and your teacher) mean by "acid" in this context. Total concentration? Equilibrium concentration? As long as the volume of titrant added is negligible, total concentration of the acid doesn't change, but equilibrium concentrations do change.
I mean total concentration of acid and not equilibrium concentration.
So the total doesn't change, but the concentration of HA goes down.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
11K
